Massive oil leak, passenger side.
Old Mar 4, 2016 | 12:05 PM
Trap Star's Avatar
Trap Star
Default Massive oil leak, passenger side.
Ok so this is a big leak. As soon as you crank the car on everything from the alternator down gets drenched. All over the filter, everything. I put in 2 qts just to test, cranked on, ran for 2 seconds, cut it off. Both quarts are now getting soaked up by kitty litter. Oil cooler leak maybe? Any help is appreciated.
Old Mar 4, 2016 | 12:59 PM
jhc's Avatar
jhc
General & Tech Moderator
You need a dry rag, a good flashlight and a helper to start the car for 5 seconds at a time. Or start at the bottom where it's worst, and go up. Post up when you find it. Good luck!
Old Mar 4, 2016 | 01:22 PM
Trap Star's Avatar
Trap Star
Thanks man. Problem I'm having is that 5 seconds is all its taking to dump huge quantities of oil. The only thing I can think is that oil cooler gasket. I had to replace the lower coolant line that runs to the cooler already. Guess I didn't pay enough attention when I rested it on a tire for transport.
Are there any oil lines in that area I should check that I may not be seeing?
Old Mar 4, 2016 | 04:08 PM
jhc's Avatar
jhc
Relax, man. I'm in ATL, I'm off tmmrw. Happy to help you trouble -shoot. Pm me.
Old Mar 4, 2016 | 05:46 PM
nizmo_0385's Avatar
nizmo_0385
RESPECT man!
Old Mar 5, 2016 | 10:37 AM
Trap Star's Avatar
Trap Star
So I've determined that the leak is coming from somewhere above the alternator but below the P/s pump. Ideas?
Old Mar 7, 2016 | 01:54 AM
KJFire4Life's Avatar
KJFire4Life
Hmmmmmm, i gotta look at my Z here in a couple minutes when I go outside. You got me seriously curious what's in between those two parts now.....Hell I been in there tearing crap apart enough i should know, post back in bout 20 minutes xD Just getting off work
Old Mar 7, 2016 | 08:22 AM
Trap Star's Avatar
Trap Star
Good stuff, appreciate man. I went ahead and pulled the alternator and p/s pump to see what I could find. Wasn't very successful haha. Did a little RTV in a couple spots that looked questionable though. I've got about 2 hours before it's fully cured (24hr mark), then I can try starting it again. Hopefully it works cause this oil is getting expensive fast.
Old Mar 7, 2016 | 02:37 PM
RWDBajan's Avatar
RWDBajan
The only thing I can think of other than a big hole in the sump is that the tube for the dipstick is disconnected. But I am going with big hole in the sump.
Old Mar 9, 2016 | 04:16 PM
Trap Star's Avatar
Trap Star
Well I found my problem. There's some ransom 12mm bolt on the block near the alternator. Looks just like any other bolt, but this one will shoot oil everywhere if you remove it. Thanks nissan hahaha.
Still have a bit of oil dripping onto the driveway. Really hoping it's just left over oil from the prior leak. If not I'm pretty clueless as to where it's coming from. Everything looks normal.
Old Mar 9, 2016 | 04:25 PM
travlee's Avatar
travlee
Master
spray brake cleaner all in that area, will get the oil off and if still leaking will be easier to locate
Old Mar 9, 2016 | 06:28 PM
RWDBajan's Avatar
RWDBajan
If you'd have said you'd been messing about and removed some "ransom [sic] bolt" it would have helped prevent wasted time. Why would you do that anyhow?
Old Mar 11, 2016 | 10:14 AM
Trap Star's Avatar
Trap Star
I bought the car pretty much in boxes. Since the motor was out already I decided to clean it up pretty good. Im assuming that I removed it during that process. If you've ever seen it before you'd understand.
Old Mar 11, 2016 | 10:33 AM
NissanZcrazy's Avatar
NissanZcrazy
So you've fixed the leak then?,what does his 12mm bolt hold down ?
Old Mar 11, 2016 | 11:29 AM
Trap Star's Avatar
Trap Star
From what I can tell it doesn't hold anything down. It's really weird. I still have a leak someplace but it's not major. I've been distracted by my headlights so I haven't looked for it.
Old Mar 16, 2016 | 09:56 AM
rcdash's Avatar
rcdash
Perhaps that is where the stock oil pressure sensor goes?
Old Sep 30, 2022 | 09:10 AM
CCJ350GT's Avatar
CCJ350GT
I’m losing oil in an undetectable location from the same general area. Can you direct me to the bolt’s location? (Yes, I know this threat is old but 🤷🏼‍♂️).
03autoz
Mar 5, 2016 12:27 PM
Nolan23
Mar 1, 2016 03:20 PM
Detailed Image
Cleaning & Detailing
Mar 1, 2016 04:43 AM
