Hesitation no powers limp mode
Old Mar 30, 2016 | 02:11 PM
kcplingram's Avatar
kcplingram
Default Hesitation no powers limp mode
350z has no response for accelerating. Problem is coming and going and now it all the time. Changed fuel pump mass air flow and throttle body. Has no code and Nissan dealership said it was the exhaust resonator. Change it no good. Anyone one with an idea
Old Mar 30, 2016 | 02:15 PM
travlee's Avatar
travlee
Master
what did you recently change before this started happening.... what year... why are you just throwing parts at it?
Old Mar 30, 2016 | 02:51 PM
kcplingram's Avatar
kcplingram
It a 03 65k miles. Didn't change any parts it just started acting up and got worse all the time now. Throwing parts because it has no codes.
Old Mar 30, 2016 | 02:57 PM
travlee's Avatar
travlee
Master
no everything throws codes. i would check for a vacuum leak on the intake. you are (assuming) a new owner, if so what all did the previous owner do to the car? plenum spacer anything like that?
Old Mar 30, 2016 | 03:03 PM
kcplingram's Avatar
kcplingram
Yes checked for vacuum leak. It's all original. When you nail the gas you can hear it breathing but takes off slow
Old Mar 30, 2016 | 03:08 PM
travlee's Avatar
travlee
Master
is it true limp mode, wont go over like 2500 rpm... or just real bad hesitation? could have clogged cats, but low mileage
Old Mar 30, 2016 | 03:12 PM
kcplingram's Avatar
kcplingram
Dealership said cats ok. How do you check cats. Does this car have a true lump mode.
absurdparadox
Nitrous Oxide
Apr 27, 2016 05:37 AM
CK_32
Apr 1, 2016 08:06 AM
Suspension
Mar 29, 2016 06:52 PM
NissanZcrazy
Tuning
Mar 21, 2016 08:30 AM
bocbos
Mar 4, 2016 09:35 AM
