New Tranny + Nismo Flywheel + Nismo Clutch @ Performance Nissan
Old Feb 16, 2004 | 08:41 PM
Phatmitzu's Avatar
Phatmitzu
Thumbs up New Tranny + Nismo Flywheel + Nismo Clutch @ Performance Nissan
Was sorry to said that I had the common tranny grind problem that some of us had. Mine was a 04' Enthu, picked it up almost 4 weeks ago from Perf Nissan. Am happy to tell yaˇ¦ll that I dropped my car off this morning to have it replaced with the newest ver. Tranny! The process was surprisingly easy and fast. Michael at Perf Nissan got me thu the paper works in 10 mins. Jason helped me to pick out the flywheel/clutch combo. The car was ready for pick up at around 5:30pm.
First impression was the clutch is much tighter than stock, and there are almost no free play. Almost as soon as you release the clutch, it picks up. New tranny works great. No grind, no hard shifting. Smooth and quiet. Tho the clutch is heavier, its very easy to pick up. Very streetable. Engine revs up noticeable faster. Did not punch the gas yet cuz I kinda wanna break it in first but the car does accelerates faster.
Q: However, the flywheel growls under 2k RPM? is that normal? It gets pretty loud if I gas it at low RPMs. But above that runs/sounds like any other Z...just faster
I give Performance Nissan an A+ no doubt. Service, knowledge and price. Dont I feel lucky that I live only 10 mins away...
Old Feb 17, 2004 | 04:55 AM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
Glad you like it! The noise is normal. They should have explained this to you ahead of time, and I'll remind eveyone here of that fact. The stock flywheel is a dual mass unit with a chunk of rubber in the middle to absorb tranny noise...... you no longer have that! Enjoy...
Old Feb 17, 2004 | 06:52 AM
Iezzi's Avatar
Iezzi
Jeff do you know anyone at smithtown nissan in NY/longisland? I have a 03 performance with 3rd gear grind and I am looking for a good dealership to take it too. I would love to have it don at Performance Nissan but I am in PA.
Old Feb 17, 2004 | 07:11 AM
___DJK___'s Avatar
___DJK___
Has anyone else with an 04 had their tranny replaced??
Old Feb 17, 2004 | 07:33 AM
Road Warrior's Avatar
Road Warrior
also, what were your symptoms of that bad tranny...us 04'ers would like to know....tx
Old Feb 17, 2004 | 08:52 AM
Phatmitzu's Avatar
Phatmitzu
Grinding(I can both hear and feel) 1st to 2nd when the cars cold, after the car warms up, I can still feel the clip(only feel). Sometimes I had problem shifting into 3nd and 5th on the freeway. After moving forward slowly, had problem shifting into reverse(when making a 3 point U-turn).
Old Feb 17, 2004 | 09:16 AM
___DJK___'s Avatar
___DJK___
Not to hijack your thread and turn it into a repair topic, but was it a loud grind? I get a small grind in second when the car is cold when i shift slowly. Its not a loud grind though, very soft. My tranny also makes a hell of a lot of noise, but I thought that was normal based on the comments Ive heard from here.
Old Feb 17, 2004 | 10:13 AM
Phatmitzu's Avatar
Phatmitzu
Originally posted by ___DJK___
...was it a loud grind? ...
Yeah, it was pretty loud. You can Def tell its not normal.
Old Feb 18, 2004 | 08:09 AM
mwaller's Avatar
mwaller
The problems Phatmitzu described are identicle to the problems I had with my '03. I, too, took my car in to Performance Nissan, and had a new transmission dropped in without hassle. Mine also came with the new clutch pedal assembly, which really gave the clutch a smoother, more polished feel. Definite improvment.
I'm less sure about the benefits of this "new" tranny, though. Shifts are noticeably lighter now, but the roughness is still there, as before, when shifting 1 => 2 when cold. Also, 2 => 3 is rougher than my old tranny when cold. However, unlike my old tranny, the roughness subsides after only 15 minutes of driving. Not sure what to make of it...
Mika
Old Feb 20, 2004 | 05:24 PM
dchi_t's Avatar
dchi_t
hey how much did u get the clutch set for? cuz im about to take my in to get my 2nd tranny replaced, <---experiencing same prob w/ 2nd tranny
Old Feb 21, 2004 | 05:01 PM
PainProphet's Avatar
PainProphet
FOR THE LOVE OF GOD, OPEN A DAMN PERFORMANCE NISSAN OVER HERE!!! :/
Old Feb 21, 2004 | 09:23 PM
Phatmitzu's Avatar
Phatmitzu
I got them for $479 I think...
Old Feb 22, 2004 | 09:22 AM
Eagle1's Avatar
Eagle1
The Nismo lightweight flywheel/Nismo clutch combination is a total no brainer mod. You have to strongly consider doing it anytime you are going to be cracking open the tranny, as the additional labor component is eliminated and basically you are just paying for the parts. The Nismo clutch performance is much better than stock, the flywheel benefit is immediately apparent, and the noise factor is truly minimal, and limited to barely audible sound at idle with the clutch out....and under moderate to hard acceleration when starting same under about 2250rpms. Otherwise, just results, no consequences. (Maybe easier to stall until you get used to the shorter engage on the clutch take up, but that is all). The car is totally civil in street and traffic situations, but is more responsive in performance driving. If I had it to do over again, I might actually go one step more aggressive and put in the JWT flywheel which is even lighter at 14 pounds compared to 23 for the Nismo.
The Nismo limited slip differential is a different story. That is a bad boy that lets you know he is with you. Not bad, but not for almost everyone either, unlike the clutch/flywheel mod.
I highly recommend the flywheel/clutch mod for the performance driver. Unless you carve canyons, or do autocross/track driving, you probably do not want the LSD. It really sits the car down and grabs the road in performance driving, and on the track at Laguna Seca, especially in places like turn 2 (Andretti Hairpin), turn 8a/b (the infamous "Corkscrew"), and turn 11 (which I thought of a couple of times as "$#@% I am screwed") the impact of the LSD on exit speed was awesome. But on city street slow 90 degree turns and supermarket parking lots it chirps and barks and clunks and generally has attitude unless you learn how to work your way around its "trigger" points.
Old Feb 22, 2004 | 03:10 PM
1337's Avatar
1337
Anyone in St Louis / Memphis / Chicago area that you guys would recommend to the equivalent of Performance Nissan? My tranny is kind grinding but not at the level where I would be taking it in. I will watch it closely to make sure to do it before warranty expires if it gets worse.
Old Feb 22, 2004 | 03:46 PM
ranger5oh's Avatar
ranger5oh
In St. Louis Bommarritto Nissan is the best one here. Dont go to Lou Fusz, they suck.
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
