Need help 04 350z de $$$
Old Sep 2, 2019 | 11:47 AM
Phatpaul's Avatar
Phatpaul
Unhappy Need help 04 350z de $$$
I have a 2004 Nissan 350 Z with 147k yesterday I took off the upper and lower intake to replace my Valve covers in the process i removed the t/b and made sure not to touch the plate. I also removed the bank one vvt solenoid to lift the valve cover off and replaced both cam sensors . Started car took a sec of cranking started was a choppy at idle but seemed to rev fine then it wasnt starting ! Threw a p0234 code for cam sensor bank1 circut low voltage i replaced with a brand new cheaper sensor and now she cranks over seemingly fine but dies almost immediately ! And it wont rev when i cracnk it and it starts i can press the gas but absolutely nothing ! Im at a loss if any one can help im wondering if my t/b might have crapped out inconveniently?? It is an original unit ! Any info would help thank you
Old Sep 2, 2019 | 02:13 PM
Phatpaul's Avatar
Phatpaul
Bump
Old Sep 2, 2019 | 03:21 PM
bealljk's Avatar
bealljk
You should return the inexpensive sensor and go buy genuine nissan OEM sensors to start. From there see if the code comes back. Aftermarket sensors are problematic.
Old Sep 2, 2019 | 03:49 PM
Phatpaul's Avatar
Phatpaul
But wouldnt the throttle still work ?
Old Sep 2, 2019 | 04:37 PM
bealljk's Avatar
bealljk
The engine / ecu doesnt like aftermarket cam sensors regardless -
does the car start for more than 2 seconds?
You're also likely in limp mode
1. get OEM sensors
2. reset the TB by the reset procedure
3. clear any check engine light codes
4. get the car out of limp mode
go from there
are you 10,000% sure you put cylinder #4 and #6 coil wires back on correctly? This is often mis-matched when taken off and they are not logically placed.
Old Sep 3, 2019 | 05:30 AM
Phatpaul's Avatar
Phatpaul
I will have to double check on the coil wires and this weekend ill try to reset everything
Old Sep 3, 2019 | 05:31 AM
Phatpaul's Avatar
Phatpaul
What brand for the cam sensors hitachi?
Old Sep 3, 2019 | 07:32 AM
bealljk's Avatar
bealljk
just go to Nissan and buy their sensors … you need to eliminate every single fault that exists on your car and going with anything but OEM is leaving a small chance that something continues to go wrong.
Old Sep 3, 2019 | 11:20 AM
Heel Til I Die's Avatar
Heel Til I Die
I believe that's correct. When I replaced my sensors I recall them being Hitachi. Also, I think the original OEM sensors have been superseded by an updated model. The new ones had a metal shielding covering the black plastic.
Try courtesyparts for the right p/n.
Old Sep 6, 2019 | 12:55 PM
Phatpaul's Avatar
Phatpaul
Once i get back home from out of state work im going to give it a go
Old Sep 7, 2019 | 02:34 PM
Phatpaul's Avatar
Phatpaul
It was the cam sensors bought hitachi ones today from rock auto will install and should be fine
Squag27
Dec 17, 2019 01:42 AM
sebby_z33
Aug 31, 2019 12:58 PM
Justin Goad
Apr 1, 2017 09:45 PM
mkiv20vt
Jul 1, 2016 10:06 AM
Sam Bowers
Jan 17, 2015 01:24 PM
