2006 350z 6 speed MT have to give more gas than normal starting off
Old Mar 9, 2020 | 10:58 PM
Eight's Avatar
Eight
Default 2006 350z 6 speed MT have to give more gas than normal starting off
I’m trying to figure out if this is an engine or transmission problem. When I release the clutch you have to give it more throttle than you should to move or it will stall. It seems to have a very limited range of engagement. Almost like you are dumping the clutch every time. There is absolutely no creeping In this car. Everything is stock.
Old Mar 9, 2020 | 11:35 PM
rustyschopshop's Avatar
rustyschopshop
Would try bleeding your clutch, fresh fluid may help.
Old Mar 10, 2020 | 07:48 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Welcome- you don't mention about how many miles are on this Z, but it does sound like a clutch problem. Any service records to show when, or if, it has ever been replaced?
Old Mar 10, 2020 | 08:37 AM
travlee's Avatar
travlee
Master
do the rpm's shoot up while the car barely moves?
Old Mar 10, 2020 | 11:20 AM
Eight's Avatar
Eight
It has 160k, I’ve had it since 60k, it hasn’t been replaced. It doesn’t seem to be slipping, almost the opposite it bits hard when you release it fully. Just no soft start. It’s like starting on a hill every time you move in 1st or reverse. If you don’t give it that much throttle it will stall.
Sean Wilson
Mar 31, 2018 02:45 PM
Silver280
Dec 30, 2017 01:01 PM
jakelangbecker
Feb 20, 2015 09:18 PM
haleo
Jun 14, 2011 09:48 PM
gurchetangrewal
May 11, 2011 04:37 PM
