G35 VQ into 350z
Hi,
I have a 2003 350Z track model with a motor that has low compression on cylinders 5 and 6. I want to swap the motor out with another VQ so that I can continue to drive the car while I build the original motor. In looking around, it is a bit hard to find a complete motor out of an '03 - '05 350Z in my area (Denver). However, there seem to be plenty of wrecked G35's at my local Copart yards. I searched around a bit and got some mixed information about what would be involved with swapping in the motor from a G35.
I am currently looking at swapping in a VQ from an '04 G35 so I can avoid the RevUp stuff. Assume these questions are specific to an '04 G35 automatic going into my '03 350Z 6mt. Here are my questions:
- Will I need to use the wiring harness from the G35 in my 350Z? I have an Osiris UpRev ECU tune and an Osiris UpRev MAF on my current motor that I would like to use on the motor I swap in. My plan was to leave the bulk of the harness connected on the current motor in my 350Z when I remove it, and then swap it over to the VQ that will be pulled from the '04 G35 while both motors are out of the car.
- Would there be anything special that I would need to do to the motor coming from the automatic '04 G35 to put it in my 6mt '03 350Z? I know I will have to remove the torque converter and put my clutch on.
- Is this a direct swap, or are there sensors/brackets/mounting points that need to be modified?
- Is there anything else I should be aware of that could complicate things for me while doing the swap that I wouldn't encounter if I were to use the motor from an '03 or '04 350Z instead of using a G35 donor?
To be honest, I've never swapped a G VQ35DE into a Z, so I cannot speak from experience. Having said that, I think this swap should come off without a hitch. The harness should switch over and all sensors should be be the same.
Also @dkmura is it cool if I send you a PM?
Thanks. It would be going RWD => RWD. The only thing that may be different is the donor car may be an auto and my car is a 6mt. I think I read somewhere that it will still work, I just need to remove an adapter plate or something like that from the auto engine.
Auto and 6mt have different pilot bearings, make sure you change it out.
I am having problems with my swap. I put my 350z motor into my g35. They are both 03 de non revup. When we started the g35 it had p0300 random is fire code and it pop every 5 sec at idle. I didn’t not swap the wire harness because I was told everything was the same. I would appreciate help.
detailaddict
Jan 20, 2017 08:29 AM
frank358fr
Jul 13, 2013 09:25 PM
