Valve Clearences
Old Apr 1, 2021 | 08:20 AM
unixfreak's Avatar
unixfreak
Default Valve Clearences
Hello community, I checked valve clearences on MY06 350z RevUp, intake valves are 0.28-0.30mm all of them, exhaust valves are between 0.40-0.45mm, car has problems like slow acceleration, high fuel consumption, is this because of out of spec exhaust valve clearences? cause I checked everything and didnt found any abnormal situation, Thanks in advance
Old Apr 6, 2021 | 11:11 PM
OldManZ350's Avatar
OldManZ350
The High End Clearance Ex Lash is .416mm. (.016") this is on a brand new motor.
The difference is so very very tiny. less than .0015" thousandths of an Inch
NO.......This Will Not cause or change high fuel consumption. and I doubt you could feel a change in power because of this. You would hear excessive Noise before a loss in power.
Stock Motor?
How many miles on Motor?
How about maintenence?
Old Apr 6, 2021 | 11:17 PM
unixfreak's Avatar
unixfreak
Stock Motor?
100k miles, stock motor, new timing chain & tensioners installed. So I feel that car is choking, 100-100kmh is about 15.5-16 sec, before it was between high 13s to 14, I dont know what else to blame, I really need to know if it’s valve clearences will take care of it, thank you
Old Apr 7, 2021 | 12:06 AM
OldManZ350's Avatar
OldManZ350
No, the Value Clearance you have is fine with a motor of 100k, this is NOT the problem.
It could be so many things......
Have you done,
New Spark Plugs?
Before & After New timing chain & tensioners, was there any difference?
Does the Motor Run Smooth?
Old Apr 7, 2021 | 12:36 AM
unixfreak's Avatar
unixfreak
Have you done,
New Spark Plugs?
yeah it was running smooth after changing timing components. this started happening two weeks ago, fsm mentioning 0.29-0.37 for exhaust valve clearence, it’s 0.40-0.42-0.45 and it’s not affecting power band? btw spark plugs is the good mention, I didn’t changed yet, therefore I have them in the garage and will install this weekend
Old Apr 7, 2021 | 12:57 AM
unixfreak's Avatar
unixfreak
P.S car is uprev flashed, I am self tuning. however I see lot of knocks, did also leakdown test and in all cylinders is only 5-8% loss, changed MAF sensor, absolutely no codes. when logging IVT,EVTs are good too. its even knocking when I hit gas pedal on stationary position, when its cold I hear slight ticking noise, when coolant goes to 70-80 there is no ticking noise, I hope its helpful information
Old Apr 8, 2021 | 10:46 AM
OldManZ350's Avatar
OldManZ350
If your getting "Knock" (You have 93 Octane?) either bad gas, tune is off or could be carbon build up in the combustion chamber & top of piston.
"Knock" will Retard Ignition Timing, & you will feel loss of Power.
Hope this helps.....
Tim
Old Apr 8, 2021 | 10:49 AM
unixfreak's Avatar
unixfreak
Tim
FYI I run 98 RON and sometimes 100 RON, ignition timing is stock, fueling is fine 12-5-12.8 WOT, dunno what else to look
dysfunctional
Oct 1, 2017 09:37 AM
bailey bill
Jun 7, 2009 06:16 AM
sry110
Apr 6, 2009 06:30 PM
adidaskobe
Jan 19, 2005 09:03 AM
phunk
Oct 29, 2004 11:17 AM
