CD001 swap to CD00A
Old May 26, 2021 | 08:41 AM
JUSTINC2001's Avatar
JUSTINC2001
Default CD001 swap to CD00A
So my 5th gear is starting to grind in my 2003 350z with a CD001
i would like to swap with the CD00A and I’ve emailed Z1 and they say for the swap it has the correct pivot ball and shifter fork I need and I just want to ask anyone that has done the swap is this correct
Z1 says all I’ll need is probably a clutch kit and a throw out bearing
Old May 28, 2021 | 09:42 AM
Conway_160's Avatar
Conway_160
If your current clutch is not slipping no need to upgrade unless you want to. Read this 350Z G35 TO ARM INFO.psd (jimwolftechnology.com)
Old May 28, 2021 | 10:27 AM
JUSTINC2001
well a 17 year old installed the clutch in his driveway before I bought it and I just want to redo it and make sure it’s done right
also from multiple people I heard you don’t swap some trans parts to fit the cd000 people do just because there stronger correct or wrong ?
Old May 29, 2021 | 05:35 AM
Conway_160's Avatar
Conway_160
If the tranny comes with the pivot arm and ball no need to change anything. I heard the older arm were weaker and could break with high clamping force clutches.
Old May 29, 2021 | 05:37 AM
JUSTINC2001
oh okay cool than I’ll be good I’m just going to use the basic replacement clutch kit from Z1 I have a lightweight flywheel now but I want to get rid of it because the chattering noise it makes over the next few months I want to get rid of as many odd noises that my car makes as I can
Old May 29, 2021 | 12:35 PM
Conway_160's Avatar
Conway_160
From what I have seen and heard, all Single Mass Flywheels and Clutches chatter. Some more than others.
My JWT HD Clutch/Flywheel makes a good amount of noise at idle.
Old May 29, 2021 | 12:41 PM
JUSTINC2001
Yeah this car came with a lightweight flywheel and I literally thought the throw out bearing was going bad as soon as I got it bc it was my first manual trans
Old May 29, 2021 | 01:14 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Highly recommend JWT HD clutch with 26lb nodular iron single mass FW. Has enough weight to keep the chattering to a minimum and engagement and tractability on the road doesn’t suffer like having a lightweight. Did that once back in the day..... NEVER again on a street car.
Old Mar 17, 2022 | 08:28 PM
AF_GARCIA's Avatar
AF_GARCIA
Hey my guy did you ever get your CD00A transmission?
84ttopcoupe
Engine Swaps
Sep 19, 2023 09:42 AM
EternalLS
Nov 18, 2020 09:07 AM
rob2496
Engine Swaps
Dec 19, 2018 06:30 AM
blackdynamite33
Oct 18, 2013 02:09 PM
xilovelsdx
Aug 18, 2011 09:59 AM
