Not starting
Old Mar 12, 2022 | 12:17 PM
schmied4's Avatar
schmied4
Default Not starting
My 2006 350z has sat for about 3-4 months while working on it and I just got done, brand new battery and will not start. Cranks but will
not turn over. Tried starting fluid to see if it was bad gas and nothing still. I check all the fuses and swapped relays that have something to do and still have nothing. I did check for power at the coils and there is when ignition is on. My doors were open for an extended period of time. Could that cause the NATS to go haywire and cause it to not start. Cam or crankshaft sensor?
Old Mar 13, 2022 | 04:43 AM
jhc's Avatar
jhc
General & Tech Moderator
Welcome.
Perhaps you could be more specific- why was it undrivable and what work did you do?
Old Mar 13, 2022 | 04:50 AM
schmied4's Avatar
schmied4
Originally Posted by jhc
Welcome.
I was doing a wide body and wrap. Cosmetic things
Old Mar 13, 2022 | 05:32 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Codes?
Old Mar 13, 2022 | 08:28 AM
Ponyryd's Avatar
Ponyryd
Need to check codes first, but if you have power on one side of the coil, check the other side with a test light while cranking and you should have a pulsing ground, im guessing you won’t have that, which could be something as simple as a crank sensor.
Old Mar 13, 2022 | 08:55 AM
schmied4's Avatar
schmied4
checked codes and there was none. Did a ecu reset, replaced crank and swapped cam sensors with new ones not oem though.
Davinder
Jan 29, 2024 07:06 AM
Bak3rme
Nov 24, 2015 08:24 AM
akbayati1287
Jul 21, 2011 07:31 PM
digitaltrance
Jan 19, 2011 12:06 PM
Diesel350
Dec 28, 2007 05:52 PM
