Engine Coolant Question
Old Apr 15, 2023 | 06:43 AM
Sickboy101's Avatar
Sickboy101
Lightbulb Engine Coolant Question
Hi Everyone,
I’m planning to drain and replace my engine coolant. I picked up the Blue “long life” engine coolant (see picture below). When I called the Nissan dealership they insisted not to use the Blue as they said it is not compatible with my engine. I was under the impression that the blue and green coolants are interchangeable. I decided to call 3 different dealerships and all the techs said to only use the green concentrated coolant and mix it 50/50 with distilled water. My car is a 2006 Rev-up and currently has green coolant.
thoughts?
Old Apr 15, 2023 | 02:43 PM
i8acobra's Avatar
i8acobra
I was a Nissan Tech for 4 years. Around 2013, Nissan started using blue coolant. They recommend not using green in anything newer than 2013. I don't think the blue will hurt your car, but it's more expensive than the green, which is what came in your car from the factory. I'd return it and get the green.
Old Apr 15, 2023 | 02:55 PM
Sickboy101's Avatar
Sickboy101
Thanks for the advice! I’ll return it and get the green coolant.
Old Apr 17, 2023 | 10:36 AM
allmightsu's Avatar
allmightsu
I put a green one as it comes from the factory and would go with it again. I bet a blue one wouldn't harm the engine, but still will put what manufacturer recommends.
Old May 18, 2023 | 11:00 AM
Aeneas137's Avatar
Aeneas137
I put blue in the Nissan, green in the Mustang, red in Porsche. but who knows if the color actually makes any difference?
Old May 19, 2023 | 05:15 AM
eZg's Avatar
eZg
Change it yet??
Rem to pour is slowwwwwwwwly to decrease the air pockets/bubbles.
Purging the air from system is a b!tch.
Old May 19, 2023 | 11:36 AM
Aeneas137's Avatar
Aeneas137
I've done it three times in the past year on my Z. what works great for me is to use a huge funnel. I've got one of those XL funnels from AutoZone which I set in the radiator opening, half full of coolant. start the car. go through a series of idle and 3K rpm for about 10 seconds at a time, alternating. while it's idling, I go back to the engine and keep an eye on the level in the funnel. you'll see bubbles coming up into the funnel. after about 5 minutes of this, I shut off the engine, and come back in about an hour to do it again. that may not be necessary but that's what I do.
JDMStanced
Dec 18, 2013 09:09 AM
IB Systems
Jun 18, 2009 06:38 PM
mesulli
Oct 29, 2005 06:26 PM
Speedracer
Nov 7, 2004 06:04 PM
