NA Power
Old Mar 10, 2004 | 01:01 AM
nz represented's Avatar
nz represented
Default NA Power
hi
I was wondering how much power the 350z can net, with out using forced induction ? What is the maximum amount of Kw , or hp it can create at the wheels (no turbo, no sc) regardless of how much money i spend on the engine. Is it anywere near 350 Kw ?
I like NA tuning because it is a little more reliable, and i dont like turbo lag.
Thanks for any help !
Old Mar 10, 2004 | 01:43 AM
shinz's Avatar
shinz
i think the max right now, someone is putting down 290-300ish rwhp n/a. Could be more now, not sure on that.
Old Mar 10, 2004 | 01:53 AM
apsilon's Avatar
apsilon
I think that'll be a difficult ask. You're talking about a 70% increase in output. Not impossible but you're going to lose some driveability and refinement and be left with a unhealthy bank balance.
Personally I don't believe NA is any more reliable than FI and lag has been relegated to the 80s and incorrectly sized turbos.
EDIT: BTW a Nismo crate engine would give you 335kw and IIRC was around AUD$50,000 when I did the conversion.
Old Mar 10, 2004 | 03:07 AM
zillinois's Avatar
zillinois
I think we had a discussion on this before, you might want to do a search. I think we found the max hp for a 3.5ish liter motor was about 450hp. That is basically a full on race motor, which would be difficult to drive around town and have a very narrow powerband. 330-380 is acheived by some 6 cylinder Bimmers and Porsches. Porsche GT3 has 380 hp(flat 6) and BMW M3 (inline 6) has 330hp.
Old Mar 10, 2004 | 04:43 AM
PhoenixINX's Avatar
PhoenixINX
mjedens is laying down 304 NA.
There is still more he could do.
Old Mar 10, 2004 | 04:53 AM
PoWeRtRiP's Avatar
PoWeRtRiP
350 is possible on these motors with a lot of work, 330 would still be very streetable and could be achieved with some internal work, noone has really messed with the heads yet and mjedens got 304 with boltons cams and high comp pistons. a cheaper alternative would be to raise compression through the heads i.e nismo heads which also flow better plus some good cams should yield around the same if not more than he did. also try raising the redline for more power has anyone tried to build an 8000 rpm vq? would make for some interesting results
Old Mar 10, 2004 | 05:43 AM
PhoenixINX's Avatar
PhoenixINX
Mjedens is running forged internals STOCK COMPRESSION. It's bored .20 over, which has raised compression ever-so-slightly.
As for raising the rev to 8k... From what I have been told the engine is internally balanced to 6600-7000. Another 200rpm or so is within tolerance, but 8k... it'll shake itself to pieces.
Old Mar 10, 2004 | 05:55 AM
PoWeRtRiP's Avatar
PoWeRtRiP
i know that i mean actually building it to handle 8k while replacing internals balancing the crank etc. i thought he had more comp, wow he could have gone higher and gotten even more, so there is definitely more power to be had!
Old Mar 10, 2004 | 06:46 AM
PhoenixINX's Avatar
PhoenixINX
Exactly...
11.5 - 12.0 would have been nice.
Well... for an NA application.
For that big shot of NOS he's going to fire it wouldn't be!
Old Mar 10, 2004 | 07:35 AM
Dom's Avatar
Dom
Wouldn't that be around 390whp?
Old Mar 10, 2004 | 08:17 AM
ares's Avatar
ares
Veteran
F1 engines make 800hp without a blower. of course they rev to 18000RPMs. by the time you got your car there, I dont think Id call it a VQ anymore. forged aluminum block, hydrolic lifters, forged internals ect ect. basicly a whole new motor that happens to fit into the Z. and to be honest, the Z isnt worthy of such an engine.
Old Mar 10, 2004 | 08:36 AM
PhoenixINX's Avatar
PhoenixINX
Go buy a Moostang.
Old Mar 10, 2004 | 11:42 AM
Dom's Avatar
Dom
they rev over 19000 right now
Old Mar 10, 2004 | 05:30 PM
apsilon's Avatar
apsilon
Sorry, I was talking in kw as was the original poster.
Stock is 206kw + 70% = 350kw
350kw = 469hp BTW
Old Mar 10, 2004 | 05:41 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Highest HP I ahve seen to date on a street diven car in this country is mjdens - in japan its Esprit's car, whcih is right at 350 hp, all NA, with pistons, cams, ecu, exhaust, headers...the usual suspects.
Ares - Hydrauic lifters on a high HP car - definately not what you want
Old Mar 10, 2004 | 06:56 PM
apex locator's Avatar
apex locator
if mjedens is on ~stock compression, what are his current mods that bring him to 300 whp?
Old Mar 10, 2004 | 09:22 PM
FLY BY Z's Avatar
FLY BY Z
Every bolt on you can buy, his pistons are 11.5:1 shaved to 10.5:1 so for all intents and purposes very close to stock, forged internals, cams (268), etc., flywheel.... I am sure the rebuild gave him a little extra if it was balanced which I think it was. Don't remember everything. The Top 10 NA Z list has a list of his mods.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
codek
Sep 28, 2015 03:03 AM
