Pistons
Old May 1, 2004 | 11:30 PM
johanna1's Avatar
johanna1
Default Pistons
Looking for some pistons for when I install my vortech kit. Any companies make pistons for the 350 yet? Thinking about just going with the AEBS stroker kit.
Old May 2, 2004 | 02:41 AM
mjedens's Avatar
mjedens
The kit comes with pistons! SGP Racing has everything else you might want. Go to their web site.
Old May 2, 2004 | 11:18 AM
johanna1's Avatar
johanna1
Thanks. Anyone else have a results yet? Can you change just the pistons without removing the rods?
Old May 2, 2004 | 12:00 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
the vortech kit comes with pistons? really??
Old May 2, 2004 | 12:27 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the AEBS stroker kit does
there are quite a few sets of pistons offered
Old May 2, 2004 | 02:29 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Old May 2, 2004 | 04:07 PM
NismoGCoupe's Avatar
NismoGCoupe
if your changing your pistons you might as well change the rods while your at it
Old May 2, 2004 | 04:26 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
http://www.i-m-racing.com/vosukit35.html
No pistons, where did you hear that it came with pistons?
Old May 2, 2004 | 05:41 PM
Z1 Performance
Former Sponsor
he said the AEBS stroker kit (obviously) comes with pistons.....
Old May 2, 2004 | 07:31 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
hehe..funny how two people can interpret the same sentence two different ways. That would be soooooo cool if the Vortech can with LC pistons...all for $4500! Nice....
But seriously...there are several good companies making LC pistons for the Z. Just look around. I might go with Arias...they manufactere then locally her near LA, and they can customize them however you want. They can put heat coatings on them as well, and you can choose the rings and stuff....
Old May 2, 2004 | 09:41 PM
dank311's Avatar
dank311
so GQ, when are you going to build your engine?
Are there any other parts in production now for building the VQ to handle more boost?
Jon
Old May 2, 2004 | 10:29 PM
Sharif@Forged
Forged Performance
i intend to aquire a junkyard (but intact) engine from a Maxima or whatever...they are all the same blocks essentially.
Once I do that, I will have the motor built up slowly over a 3 month period. I have no decided yet who/where. But I will go with a sleeved, semi-closed deck, and lower compression forged pistons and H-Beam forged con-rods.
Like I said, if you want something off the shelve, there are plenty of read-to-go piston and ring sets for the VQ. Check with Performance Nissan or any import tuner mag. I havent done much research on the rods yet, but I assume they rods as well.
You may have seen the post about the Nissan dealership in boulder CO, that is building the LC VQ motor and put down some serious numbers. There will undoubtedly be some VERY good learnings that come out of that operation. We are all waiting patiently until they post a detailed write-up and dyno charts. Looks very promising though...and I am salivating at the prospects of a 700whp 350Z
Old May 3, 2004 | 11:37 AM
G3po's Avatar
G3po
Default LC and Vortech
Keep in mind using LC (ie 8.5 etc) in a TT or Roots SC setup would be sweet; however, with a Cent SC like Vortech or ATI , it will perform like a "slug" on for street use. The high CR and the Vortech tend to complement one another. The higher CR gives crisp throttle response down low were the Vortech's (ramped boost profile lacks.
Hey GQ , do you think it's possible to lower the CR on the VQ and still pass the sniffer test?
Old May 3, 2004 | 12:18 PM
Jason@Performance
Performance Nissan
there was a VQ35 out of a maxima here... not sure if its gone yet..
Old May 3, 2004 | 12:37 PM
PoWeRtRiP's Avatar
PoWeRtRiP
how much would a vq35 out of a max cost, is it exactly the same, and what year maximas have it???
Old May 3, 2004 | 02:53 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
2002+ have the VQ35, not sure of the cost though
Old May 3, 2004 | 03:03 PM
G3po's Avatar
G3po
Default CR on Maxima
Know what the base CR is on the 2002,3,4 maxima VQ35s?
Old May 3, 2004 | 03:33 PM
rubes10's Avatar
rubes10
just wanted to let you all know that the 350 block and the maxima block while being the same architecture are 2 different castings, meaning that engine mounts and accesory pickup points are completely different. also the front timing covers are different also. just wanted to give you a heads up before someone spends money on one. however the heads are identical.
Old May 3, 2004 | 03:58 PM
03BlkSETE's Avatar
03BlkSETE
Default Re: CR on Maxima
10:3/1 on the 02, 03's. Not sure about the 04's.
seagrasser
Oct 11, 2015 03:27 PM
B Esquire
Sep 24, 2015 07:52 AM
hardkicks
Sep 20, 2015 12:28 PM
