anyone dyno with these exact mods??
Old May 18, 2004 | 08:29 PM
rodH's Avatar
rodH
Question anyone dyno with these exact mods??
Crawford Plenum
test pipes (or high flow cats)
JWT intake (or K&N cone)
Nismo exhaust
UR Pulleys
just curious about what I might be running in the near future??
Old May 19, 2004 | 05:08 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I dynoed close to that, JWT, Crawford Plenum, test-pipes and an Injen exhaust
**5th gear SAE corrected**
254whp
245 ft lbs
I now have a pulley but havent dynoed yet. Hope that helps...you should be in the mid to high 250 range.
Old May 19, 2004 | 05:30 AM
PoWeRtRiP's Avatar
PoWeRtRiP
^what he said^
Old May 19, 2004 | 07:21 AM
alex30327's Avatar
alex30327
Crawford plunum, UR crank pulley, stock intake, injen exhaust, nismo headers, and crawford cast= 261 rwhp on dyno.
Old May 19, 2004 | 11:32 AM
zxsaint's Avatar
zxsaint
Fairlady Stalker
^what they all said^
Expect 250-260
Old May 19, 2004 | 11:39 AM
VandyZ's Avatar
VandyZ
I concur!
Old May 19, 2004 | 11:47 AM
PoWeRtRiP's Avatar
PoWeRtRiP
the really cool thing is that if you add crawford headers and jwt cams to that list, expect high 290s
Old May 19, 2004 | 09:42 PM
rodH's Avatar
rodH
thanks a LOT GUYS!!!!
that is pretty good HP, that should equal about 310 at the crank.
PoWeRtRiP, Good point, I am not sure I want to ever do Headers though, the install cost is just waaaaaaaaay to high. JWT cams, maybe, I know they cost a lot too, but I think with test pipes and exhaust, I would get waaaaaaaay more out of cams than I would headers.
Old May 20, 2004 | 12:10 PM
TheBigShow's Avatar
TheBigShow
a good set of headers would really help the cams though.
Old May 20, 2004 | 12:12 PM
PoWeRtRiP's Avatar
PoWeRtRiP
so dont pay to get them installed, i did my headers with a friend in 5hrs on jackstands. its not hard, the only thing i would never install myself is cams, anything else is diy. and its pointless to do cams without headers your engine will choke on the stock log headers.
Old May 20, 2004 | 01:26 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
JWT moves the powerband way up, leaving you limp down low with all the power above 5k. I wouldn't do them or recommend anyone get the JWT cams without a raised rev limiter, so i'd suggest adding the TS flash to the mix. At that point you're looking at close to another $2.5-$3k to get to 290
my $0.02
Old May 20, 2004 | 02:00 PM
ElvishasaZ's Avatar
ElvishasaZ
what about torque do you loose anything with the nismo or jwt cams?
when they say add 13-16 HP is that already on top of something like you have if your already @ 250ish?
3vilbunny
Jul 18, 2017 05:10 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Tochigi_236
Sep 27, 2015 03:40 PM
