Honking Noise when clutch is depressed??
Old Jun 5, 2004 | 05:21 AM
Z350Lover's Avatar
Z350Lover
Question Honking Noise when clutch is depressed??
Hello guys,
I notice my car has this kind of honking noise as soon as I depress the clutch at 4000 rpm while changing into any higher gear (sounds like I have my clutch linked to my horn, but not as loud) ... and it is more obvious with the car's moving and with the lighter flyghweel (I can also reproduce the noise when car is at standstill position while I am revving the engine up)....
I thought it only happened to the light weight flywheel, but nissan put the stock flywheel back on and still.... it has that noise, but not as loud as with the light weight flywheel on. Nissan does not know what noise is that and what causes it, so they "presume" that's a normal operating noise, so the light weight flywheel is back into the car again...
I heard people mentioning about this about 1 year ago, not too sure how long back.... so does anyone know what kinda noise is that? why would it only happen in between 4000 to 4500 rpm, not any lower or higher?
Any input/opinion will be appreciated!
cheers,
richie
Old Mar 28, 2011 | 01:11 PM
Beaker02's Avatar
Beaker02
Ive got it too. Like you say, it sounds like a honk but its obviously a vibration. The first time i heard it i thought someone had honked at me. only happens when clutch is depressed. Any ideas?
Old Mar 28, 2011 | 01:12 PM
Beaker02's Avatar
Beaker02
.....and engine is reved.
Old Mar 28, 2011 | 02:34 PM
plumpzz's Avatar
plumpzz
holy old thread. i remember when richie did the worlds first 3.8L na nismo build. **** was nasty.
Old Mar 28, 2011 | 04:21 PM
Shertown Turbo's Avatar
Shertown Turbo
Almost 7 year old thread revival
Old Mar 29, 2011 | 09:48 AM
Beaker02's Avatar
Beaker02
Well great! After 7 years we should have a good idea whats up right? It might be 7 years later, but mine has just started. Is thgere another thread that addresses this? Thanks.
Old Mar 30, 2011 | 04:23 PM
kramykram's Avatar
kramykram
lol once again glad to see someone uses the search function.
Old Mar 30, 2011 | 04:37 PM
surfcity40's Avatar
surfcity40
throwout bearing?
Old Apr 12, 2011 | 02:11 AM
ffwturboZ's Avatar
ffwturboZ
I have the same issue. I also have a fairly new through out bearing that was replaced with the new clutch and still honk, honk....but only after a hard track day.. Just FYI
HOLY OLD THREAD BATMAN!!!!
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
