Car overheated today??? Any ideas
Old Jun 7, 2004 | 11:44 AM
exploder's Avatar
exploder
Angry Car overheated today??? Any ideas
Ok, i get in my car today and start drivin out of my apartment complex where by the end of the gates I am already warmed up. However, when I finally make it out on the road the car is still at all the way cold, I make it about 100 yards down the road and the needle all the sudden swings past where it normally sits when the car is warm and continues towards hot. I shut the car off and pull over before it overheats all the way. I look around and can't find any hoses that are loose, I then look under the car and see coolant dripping off the crossmember that holds the radiator in place. I add more water and it starts dripping more. Now I am thinking I have a cracked radiator, however I have never hit anything or scraped it, not even my front bumper. Now I am starting to get pissed so I go buy some radiator stop leak, put it in and fill the radiator the 2nd time and let the stop leak do its job. After all this is over I go drive it around and everything is fine and no dripping. Now my question is what could have happend.
Old Jun 7, 2004 | 11:53 AM
PoWeRtRiP's Avatar
PoWeRtRiP
have you ever messed around with anything on the radiator before i.e. installed headers, flushed radiator, installed cai, etc.
Old Jun 7, 2004 | 12:11 PM
exploder's Avatar
exploder
i have intake, long tube headers, nismo thermostat... but all of these parts have been installed for well over a year now
Old Jun 7, 2004 | 12:26 PM
PoWeRtRiP's Avatar
PoWeRtRiP
did you bleed the air out of the lines properly when you installed the thermostat, it is possible that there is an air bubble in your lines that could cause it to overheat.
Old Jun 7, 2004 | 12:42 PM
exploder's Avatar
exploder
yes i bled the air when i installed it, however that was months ago...
Old Jun 7, 2004 | 01:38 PM
mofoz's Avatar
mofoz
maybe try draining it completely and refilling it, letting it run in your garage or driveway and looking for leaks.
Old Jun 7, 2004 | 01:49 PM
teh215's Avatar
teh215
If it continues I would suggest getting a "leak trace" kit. It consists of a bottle of dye that you add to the coolant and a black light. You simply add the dye to the radiator, start the engine and let it warm up. Once it starts to leak again the dye in the coolant will fluoresce under the black light and you will be able to see exactly where the leak is coming from. It is really pretty slick.
Old Jun 7, 2004 | 01:59 PM
exploder's Avatar
exploder
thanks for the idea, I will try that
Old Jun 7, 2004 | 07:01 PM
ares's Avatar
ares
Veteran
note, you need a "portable" blacklight for that.
and its easier if its not bright out.
Old Jun 7, 2004 | 07:35 PM
exploder's Avatar
exploder
dont most of the fluores kits come with the light?
Old Jun 8, 2004 | 04:52 AM
King Tut's Avatar
King Tut
Yeah, the good kits will come with the dye and the light.
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
Katie93
Sep 15, 2015 05:57 PM
Suffolk350z
Sep 13, 2015 02:43 PM
OperatorAF
Sep 13, 2015 11:36 AM
Darkspy
Sep 7, 2015 09:09 PM
