squeeking noise from the clutch
Old Jul 28, 2004 | 08:04 PM
*510*350Z's Avatar
*510*350Z
Default squeeking noise from the clutch
does anyone have a squeeking noise from the clutch? everytime i step on the clutch it makes a squeeking noise... how can i go about fixing it?
Old Jul 28, 2004 | 09:18 PM
HanZolo's Avatar
HanZolo
When in doubt, lube it.
Old Jul 29, 2004 | 03:54 PM
phile's Avatar
phile
Default Re: squeeking noise from the clutch
I get it when i let the clutch out during shifts
Old Jul 29, 2004 | 06:17 PM
G352NV's Avatar
G352NV
Mines getting really bad! Wifes been on my case to take it in.
Old Jul 29, 2004 | 07:01 PM
redline350ZZ's Avatar
redline350ZZ
stock clutch???? or aftermarket????? I just put a tilton setup in and was told that the clutch will squeak till broken in.... the squeaking decreases everyday......
Old Jul 30, 2004 | 12:20 AM
joust75's Avatar
joust75
My clutch cable was squeaking recently. The dealer lubed it and it went away.
If you are hearing a really heavy mechanical sounding squeak then your screwed cause your clutch is gone.
Does the clutch make the sound when the car is off? Thats how you tell if its serious or not...
Old Jul 30, 2004 | 08:59 AM
HanZolo's Avatar
HanZolo
How did the dealer find a clutch cable on a hydraulic clutch?
A dab of white lithium on the pivot should take care of it. I'll try and find my squeakin mouse this weekend and post where to lube.
Old Jul 30, 2004 | 11:53 AM
*510*350Z's Avatar
*510*350Z
the clutch squeeks when the car is off and on... does that mean its really bad?
Old Jul 30, 2004 | 06:16 PM
G352NV's Avatar
G352NV
I have the same problem. I had the same problem years ago on my civic. It was a easy fix cause the tranny was right up front. I just sprayed some lube on the pivit where it went into the tranny. I know its the same problem on my G but I dont know where its on on the G.
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
