Getting transmission replaced - Need flywheel / clutch advice
Old Aug 5, 2004 | 03:16 PM
mpol99's Avatar
mpol99
Thumbs up Getting transmission replaced - Need flywheel / clutch advice
I tried searching, but no similar threads, so......
Should I get flywheel only, flywheel & clutch???
I'd prefer flywheel only for $$$ reasons.
Which one should I get, any links with prices? Who has the best prices??
Thanks!
Old Aug 5, 2004 | 03:32 PM
hfm's Avatar
hfm
You can get by with just the flywheel and keep the stock clutch without any problems. I like the JWT but June is another good option for daily driving. Try calling Performance Nissan for more suggestions.
Old Aug 5, 2004 | 07:53 PM
PhoenixINX's Avatar
PhoenixINX
<cough> Mr. HFM... Your honor?
... I believe it's JUN.
Old Aug 5, 2004 | 07:57 PM
hfm's Avatar
hfm
I was scrolling down the post after the fact and saw the same thing. It's JUN, not JUNE. Worse, after I scrolled down and saw my post referring to a month rather than a manufacturer and I see you correcting me...let's just say I've had better days.
Old Aug 6, 2004 | 04:20 AM
PhoenixINX's Avatar
PhoenixINX
I just hope you don't start talking about other great auto tuners...
... July, August, and the ever intimidating October... <shivers>
Old Aug 6, 2004 | 03:28 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
HFM, that is what overstudying for the BAR Exam will do to you.
Regarding original question, its perfectly fine to change the flywheel only. HOWEVER, might I suggest upgrading the clutch at the same time, since you'll be spending quite a bit of money to remove and replace the tranny. A quality clutch/pressure plate that wont brake the bank is the ClutchMaster Stage II for N/A, or Stage III if you are F/I. Almost the same pressure as stock, but around 100% more clamping capacity. I ordered the STAGE III for my TT car, and it has...if memory serves me correctly, 120% more clamping force.
Old Aug 7, 2004 | 06:40 PM
MannishBoy's Avatar
MannishBoy
I'm leaning toward the JWT. The dealership here has told me that they are going to warranty a clutch, too. I'm trying to decide if I should just keep the stock clutch with the flywheel, or spend the extra money on a clutch.
I've got no performance mods, so I don't need something that will handle insane HP. I'd say the stock would probably suit me fine and be slightly more streetable than aftermarket, but I can't make up my mind.
Old Aug 7, 2004 | 07:29 PM
Egbert Souse's Avatar
Egbert Souse
Default Do you wanna go Ape shid???
Tilton rally clutch and 8 lb. flywheel. Expensive but worth it. Barely streetable. Very hard to launch from a dead stop. Once you are rolling, it revs like a buzz saw. Incredible.
Attached Thumbnails Getting transmission replaced - Need flywheel / clutch advice-tilton-clutch.jpg
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
