Nismo Cams, Anything Else
Old Nov 4, 2004 | 11:40 AM
tik1's Avatar
tik1
Default Nismo Cams, Anything Else
I recently bought the Nismo Cams for my G35. I figured while the installers had my engine open I might as well get a few other parts replaced. I know a lot of people suggest getting the Rod Bolts replaced. Is there anything else I should do at the same time? I don't plan on going the FI route.
Down the road I plan on getting headers, plenum, UR pulleys, intake, and the ECU remap.
Old Nov 4, 2004 | 01:25 PM
RCKTDAWG's Avatar
RCKTDAWG
Valve springs! Please post your review after you test drive.
Old Nov 4, 2004 | 04:52 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
no need for anything else with the NISMO cams
Old Nov 4, 2004 | 10:36 PM
Barzten1's Avatar
Barzten1
What will valve springs run? $$$
Old Nov 5, 2004 | 04:25 PM
IceY2K1Max's Avatar
IceY2K1Max
http://www.z1auto.com/prodmore.asp?m...ine&prodid=922
Old Nov 6, 2004 | 07:47 PM
ChromiumBlue's Avatar
ChromiumBlue
hell, if u saved on ur cams, u mite as well try that vtc pulley, the cams are gonna rob some power at the lower end, if daily driving is in ur cars future, id get this.
Old Nov 7, 2004 | 06:27 AM
Z1 Performance
Former Sponsor
there is no need for the vtc pullies with the base model NISMO cams - they are so mild that they barely affect the bottom end. The VTC pullies are designed for much higher lift cams
Old Nov 7, 2004 | 08:01 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
upper gasket kit...
http://www.performancenissanparts.co...oducts_id=1809
nanotech
Oct 2, 2015 05:02 AM
