DIY Replacing your belts. Very Easy
Old Jul 7, 2013 | 03:09 PM
  #141
350zchad's Avatar
350zchad
subscribed
Old Sep 4, 2013 | 07:51 AM
  #142
JCat's Avatar
JCat
2004 350Z ~ 50,000 miles
A/C belt broke . . . . other belt looks shot.
Thanks to this forum and post, replacing them should be easy tonight !
Old Oct 14, 2013 | 09:29 PM
  #143
Bdizz777's Avatar
Bdizz777
Do u need to loosen both tensioners for doing just the alt/pwr str belt? I need to replace just that one?
Old Dec 5, 2013 | 11:06 PM
  #144
Dave Demlong's Avatar
Dave Demlong
Great guide, will be doing them this weekend. OEM belts came in. My 06 has 78K and probably has the stock ones (or 2nd set) I believe. I'm the 3rd owner of her. They are cracking but still holding strong with no fraying of the belt and no squeal. Quite surprised.
I liked one of the other member's comment. Count the number of loosening turns for each tension screw and use that as a base for re tightening before measuring deflection. Since most people seem to not get them tight enough that is a good idea.
Old Feb 7, 2014 | 11:24 AM
  #145
HeyYouGuyz's Avatar
HeyYouGuyz
How are people changing and tightening from the top?
Old Feb 11, 2014 | 08:19 AM
  #146
myork's Avatar
myork
You cant - you are going to have to raise the car and do most of the work from underneath.
Old Mar 12, 2014 | 10:39 AM
  #147
kamz's Avatar
kamz
Tried to do install with belts I bought online that were same size for unorthodox pulleys but grooves were different so was only able to get one of the belts on. Pretty easy install so just need to find the right belt now. Thanks for the write up.
Old Mar 29, 2014 | 08:59 PM
  #148
DVSIR911's Avatar
DVSIR911
Great writeup, just did this today, was a piece of cake. I expected to have some setbacks, but it was easy. Cranked it up and didnt have any squealing or issues at all. Is there such thing as overtightening the belts? Everything seems to be in order.
Old Mar 30, 2014 | 08:46 AM
  #149
dkmura's Avatar
dkmura
General & DIY Moderator
Yes, over tightening the drive belts will lead to accelerated wear and potential failure. I use the deflection guide in the FSM to ensure the belts are installed properly.
Old Aug 3, 2014 | 02:32 PM
  #150
_Shorty's Avatar
_Shorty
Just replaced both belts on mine. The alternator belt appears to be too long. I ran out of idler adjustment and it's only showing 160 lbs of tension. This is a bit short of the 188-208 lbs listed in the service manual. :\
Old Oct 10, 2014 | 07:14 AM
  #151
delmer350's Avatar
delmer350
Default belt changing
thanks a million for this DIY.
Yesterday I changed the 2 original belts on my 2003 (70000 miles) Z. Bought 2 Dayco belts from Advanced Auto Parts. Dayco part #'s: 5040373 & 5060463. Cost less than $30 for the two. It only took 15-20 minutes after getting the plastic shield off the bottom of the car. the only slight issue was a very tight bolt on the upper pulley. Just put a pipe on the handle of the rachet wrench and it loosened easily. I've read a lot over the years to just push on the belt with your thumb and tension it to move about 1/4". This is what I did and all seems well
Old Oct 28, 2014 | 06:05 PM
  #152
_Shorty's Avatar
_Shorty
I bought a Krikit gauge since they were so cheap, and I haven't had any slippage issues or anything so far. But it was still not quite what the service manual says it should be. It's fine, I suppose.
Old Dec 16, 2014 | 12:31 PM
  #153
carnoob's Avatar
carnoob
Thumbs up
This is really good, thanks! I was about to do it but realized my tools couldn't get in there to loosen the tension pulley nut on the power steering belt. The radiator was too close.
Old Jan 31, 2015 | 02:41 PM
  #154
Li1ag's Avatar
Li1ag
Default Thanks
Good stuff here. Just finished today. Very simple. Maybe just edit the tools you'll need in the beginning. Used a wrench in the tight spot on the pulley. I also didn't have anything to measure the lbs in pressure so I kind of winged it of how tight it was to loosen in the first place. Went good on the first go. Thanks again!
Old Mar 10, 2015 | 06:20 PM
  #155
GARYMM1187's Avatar
GARYMM1187
Thanks for the write up, replaced both of mine with OEM last week. I did not put them any tighter than what they were previously, and no squealing at startup so not too loose. I may buy a tool to measure in the future so I can be sure it's set to spec.
Old Feb 20, 2017 | 02:48 PM
  #156
spartikus1975's Avatar
spartikus1975
very old thread but can someone tell me how to make it so i can see the pictures they don't show up
Old Feb 20, 2017 | 03:28 PM
  #157
sluggoZ's Avatar
sluggoZ
I have no problem seeing the pics on page one......try again!
Old Feb 20, 2017 | 03:47 PM
  #158
_Shorty's Avatar
_Shorty
Yeah, perhaps you've got an issue with an adblocker or something mistaking the host that the images are on for an ad service. Who knows. But the pictures are all displaying for me just fine, too.
Old Jul 21, 2017 | 02:02 PM
  #159
HOMiEZ's Avatar
HOMiEZ
Any chance we can get the pictures again?
i have to agree with Spartikus that the images are not working for me either. I verified the location of the pictures where it is hosted on photobucket, but the URL doesn't go anywhere:
http://img.photobucket.com/albums/v2...l/DSCN2299.jpg
Old Jul 21, 2017 | 09:44 PM
  #160
_Shorty's Avatar
_Shorty
I don't even remember what the pictures actually showed anymore, but there really isn't much to this job. It's pretty simple.
