5AT to 6MT Swap INFO, ***, DIY, GUIDE Thread!
Old Jul 16, 2023 | 06:38 PM
  #261
nstiles26's Avatar
nstiles26
Originally Posted by EJimenez86z
hi I have a question can I use a manual Ecu with the automatic harness? Also I swapped both ecu and engine harness to a 6mt and splice the the wires but my car only cranks and almost turns over like it lets out combustion some from the exhaust and idea what it can be ?
Did you get this figured out? I’m having the same issue. I swapped both my engine harness and engine room harness out from a manual. The other harnesses are dual compatible according to Nissan parts sites. I was able to start the car by hard wiring the fuel pump. The black wire with yellow stripe runs to the IPDM labeled wire 23. This is the reason the car won’t start because it is getting 0v. I’m just not sure where the connection is being severed though.
Old Feb 7, 2024 | 05:14 AM
  #262
Bsly622's Avatar
Bsly622
Has anyone gotten the manual transmission gauge cluster to work.
Old Nov 5, 2024 | 12:39 AM
  #263
smokehim's Avatar
smokehim
I appreciate it
Old Feb 24, 2025 | 11:06 AM
  #264
Porter200's Avatar
Porter200
ik this is an old thread but i just recently finished the swap in my 2003 350z with auto ecu and auto harness.
tapped into my ipdm connector e8 pin 43 into a switched power wire and Z cranks but no start.
ive double checked my wiring and making sure i did it right
double checked cam and crank sensors, all fuses and relays, checked codes and only getting u1000/1001 which ik is normal.
ive disconnected battery and let sit overnight to drain any power left in the system
ive got fuel and all. im assuming my ecu cut spark and i cant figure out why
thanks
Old Feb 21, 2026 | 12:50 AM
  #265
350ZSKY's Avatar
350ZSKY
thanks
these 2 videos might help you, I know I've been using them as its very helpful. Idk if you're still trying to figure it out or not.
JasonZ-YA
96
Nov 13, 2020 06:52 AM
Tackett
Jun 13, 2017 12:28 PM
Cass007
Engine Swaps
May 14, 2016 07:50 PM
JG 350Z
23
Dec 31, 2012 12:30 PM
