5AT to 6MT Swap INFO, ***, DIY, GUIDE Thread!
Old Oct 15, 2017 | 12:17 PM
  #181
Atreyu'z 350's Avatar
Atreyu'z 350
No. The 350Z motor is cammed slightly more from the factory as well.
Old Oct 15, 2017 | 12:28 PM
  #182
Jonp's Avatar
Jonp
So what do I do find a manual 350 motor has to be a de manual is my only option I guess
Old Oct 15, 2017 | 12:30 PM
  #183
Jonp's Avatar
Jonp
That looks like my only option then
Old Oct 15, 2017 | 12:43 PM
  #184
Jonp's Avatar
Jonp
What about a auto 350 motor ?
Old Oct 15, 2017 | 01:43 PM
  #185
Jonp's Avatar
Jonp
Can I drop that in or does it have to be a manual ? I found one just a auto motor please help lol I'm confused lol
Old Oct 16, 2017 | 06:00 AM
  #186
Atreyu'z 350
Nope. It doesn't have to be a manual.
Old Oct 16, 2017 | 01:27 PM
  #187
Jonp's Avatar
Jonp
So I can drop a auto 350 motor in then thanks bud the guy told me it didn't matter that had the engine but I just wanted to make sure before buying it
Old Oct 16, 2017 | 04:03 PM
  #188
Atreyu'z 350
Yep no prob
Old Oct 17, 2017 | 08:16 PM
  #189
Darthnismo's Avatar
Darthnismo
Let me know how it goes. Message me on Instagram @Darthnismo
Old Oct 18, 2017 | 03:07 PM
  #190
Jonp's Avatar
Jonp
Don’t have Instagram but I sure will bud
Old Oct 18, 2017 | 05:07 PM
  #191
Darthnismo's Avatar
Darthnismo
Im getting my transmission on Friday. I already have a 2004 M/T ECU, clutch resevoir and line.
Im changing the engine harness to a M/T harness. Can keep my existing BCM?.
ALSO, How would i wire up the clutch switch?
Old Oct 19, 2017 | 04:01 PM
  #192
Jonp's Avatar
Jonp
I would think you would have to change both see if you can get the bcm and ecu if you can I would but that sounds like a lot of work bud good luck hope the best for you thats just my opinion I may be wrong I’m not a expert yet lol
Old Oct 19, 2017 | 04:03 PM
  #193
Jonp's Avatar
Jonp
I would think anything on the clutch would plug into the harness bud since you are swapping harnesses too
Old Dec 17, 2017 | 05:33 PM
  #194
Darthnismo's Avatar
Darthnismo
Question for the Zs
What did you guys do for the missing bracket that holds a bolt for the top of the clutch pedal?
Old Mar 1, 2018 | 07:30 AM
  #195
es4204832's Avatar
es4204832
Default 6mt swap trouble
ok so I'm doing the swap into a 5at car .I have the 5at ipdm and 5at dash harness ,then I I have the 6mt engine harness 6mt ecu,key and sending unit . I hooked the jumper wire to the ipdm so the car turns over but I'm getting no fuel or fire .I could be missing something please help
Old Apr 26, 2018 | 03:55 PM
  #196
bozwayed's Avatar
bozwayed
Default Pedal and bushing
Originally Posted by Darthnismo
Question for the Zs
My question exactly. Also the automatic transmission bushing is not budging. I am trying to break it still. Does anyone have the template to drill the holes for the master cylinder??
Thanks in advance
Old Apr 26, 2018 | 04:42 PM
  #197
Darthnismo's Avatar
Darthnismo
Thanks in advance
i made my own template unto a piece of metal. It worked fine for me
Old Apr 26, 2018 | 06:53 PM
  #198
vegasanthony's Avatar
vegasanthony
My question exactly. Also the automatic transmission bushing is not budging. I am trying to break it still. ??
Thanks in advance
i had to drill it out..lots of small holes..
take your time and don't damage the crank
Old Apr 30, 2018 | 03:28 AM
  #199
bozwayed's Avatar
bozwayed
Default Padel installed
I got the padel installed. I use a 3.5 inch stick to measure from bottom brake bolt to the clutch bolt. Marked it and drilled. You can see the progress on my Instagram 965spec.
Old Jun 7, 2018 | 12:43 PM
  #200
bozwayed's Avatar
bozwayed
Default Pilot bushing transmission not going in
Hi all. I got all the parts and everything is done. When i try to put the manual transmission back in their is an inch gap. It is not going in because the neck of the main transmission shaft is a bit wide at then end. Should i machine it or just remove the pilot bushing? Or is the main transmission shaft a bit longer. I asked a local mechanic and he gave me a shaft off a 350z transmission and it looks different on the end that goes into the crank as it has no diameter increase and a bit shorter. Any ideas??? Please help!!!
