Engine Swaps For all your engine swap experiences, ideas, questions, & more..
The Official LS Swap Info/Questions Thread
Old Apr 23, 2012 | 08:08 AM
  #661
QTB's Avatar
QTB
Originally Posted by Brew_haha
GM pedal bolts right in of of a GTO
I'm not 100% but the corvette (mine) has a different position sensor than the GTO. Yet another reason to buy a GTO LS2, oh the shame
Old Apr 23, 2012 | 11:01 AM
  #662
bbs350z's Avatar
bbs350z
Originally Posted by Quamen
I am landscaping my yard, pouring a cement driveway and working like 60 hours a week right now on top of revamping a ton of things on my car. On top of that I now work in Sheboygan so my drive is an hour each way...
Check out my Facebook to see more of what I have been working on.
goddamn lol, i just got back from az, bought a house lmao, im so broke now so i gotta finish this thing and out it up for sale so i can get everything ready to move out there within the year. ill swing over one of these days and well have a cigar and some brews.
Old Apr 23, 2012 | 02:38 PM
  #663
Quamen's Avatar
Quamen
I see... Moving to a state where you aren't the slowest LS swapped Z... Nice move!
Old Apr 23, 2012 | 06:02 PM
  #664
bbs350z's Avatar
bbs350z
lmao kiss my ***
Old May 4, 2012 | 08:59 AM
  #665
QTB's Avatar
QTB
How are people running their cooling fans? I have mine still wired through the Nissan ECM and they just run all the time as soon as the ignition is on.
Old May 4, 2012 | 01:06 PM
  #666
Brew_haha's Avatar
Brew_haha
Mine run off of the stock GM ECU and a relay that has the 12v+ leading to the fans.
Old May 6, 2012 | 10:23 AM
  #667
Token_Z33's Avatar
Token_Z33
Went today and checked out this motor a guy in my area posted on craiglist
Says its a LS1 with about 500 miles on it and came out of a 2003 corvette, Im a noob to this **** in case its not obvious but i snapped these pics today and wanted to get input on whether yall believe its worth the 1800 he's asking for it
From what i can see its missing the intake and exhaust manifolds and the belts but other than that im not 100% on what im looking at or looking for
Thanks in advance
Old May 6, 2012 | 02:28 PM
  #668
Rambo's Avatar
Rambo
It is also missing the oil pressure sensor and knock sensors. Some of the holes looked gummed up.
Definitely out of a late model c5 vette from what the oil pan looks like. LS6 block based on casting number (1251168), 241 LS1 heads, late model ls6 pcv valley cover.
The engine over all looks very clean. I dont know how you are looking at a 500 mile 9 year old motor, but looks pretty clean. I would go 1500 for the long block complete if you can get him down that low.
Old May 6, 2012 | 05:29 PM
  #669
Token_Z33's Avatar
Token_Z33
Thank you for the input! and yea needless to say i was concerned about the mileage myself but it didnt look too bad to me, thats why i got on here to ask
Ill post up what happens tomarrow...if i pick this up im getting right into buying parts to finish it off
Old May 8, 2012 | 08:29 AM
  #670
Cass007's Avatar
Cass007
Also missing the coil packs, throttle body. No big deal if you are considering running a FAST setup and aftermarket TB.
Old May 8, 2012 | 08:31 AM
  #671
Cass007's Avatar
Cass007
Franz figured out how to control mine like stock, at a certain temp they turn on (possibly one at a time) and cycle as needed by the car to maintain max/min operating temps.
It was 82*F this past weekend and the car took a beating and had zero issues.
Old May 8, 2012 | 11:34 AM
  #672
bbs350z's Avatar
bbs350z
^can you haz ask franz for details hunnybuns?
Old May 9, 2012 | 07:01 AM
  #673
Brew_haha's Avatar
Brew_haha
Mine runs off of the stock GM ecu with a relay triggers the fans to kick on at whatever temp is set at in the ECU by HP tuners which is 190 deg right now
Old May 9, 2012 | 09:37 AM
  #674
QTB's Avatar
QTB
I don't believe my harness has anything for fans. Yet again foiled by not using the Chase Bays harness.
Old May 9, 2012 | 10:10 AM
  #675
Brew_haha's Avatar
Brew_haha
No bueno its a standard for ours, i was even working on DLC plugs to use for LS1/LS2 harnesses for a competitor of ours the other day.
Old May 9, 2012 | 01:03 PM
  #676
Cass007's Avatar
Cass007
No GM ecu for me. I believe he figured out how to use the Nisaan ECU to control them, not the ViPEC, but I may be mistaken.
I am sure this is one of the special things that he would hope to be paid to do for others. I know there is at least one other member that is basically repicating my setup, but with a built LS2 that will put down some serious HP NA.
Old May 9, 2012 | 01:56 PM
  #677
Brew_haha's Avatar
Brew_haha
Just depends on how it is wired if you use the stock VQ ECU and its just being used as a CAN pass through then you need to use the stock nissan one on the LSX motor and have the stock chassis wiring for the fans plugged up.
If using the GM ecu and not a stand alone it will just use the stock GM ECU go to a relay that is controlled by the ECU then 12+ to the fans once the desired temp is reached.
Old May 9, 2012 | 02:33 PM
  #678
QTB's Avatar
QTB
Okay so in theory I could just run the +12V signal wire to the Nissan relays to energize them since I have the fans all wired in through the Nissan harness?
Old May 10, 2012 | 06:59 AM
  #679
Brew_haha's Avatar
Brew_haha
Correct as long as you have the nissan sensor in one of the ports on the heads and the ECU sees that signal then you are good to go.
Old May 10, 2012 | 09:29 AM
  #680
bbs350z's Avatar
bbs350z
^logan, does your coolant gauge work with your harness? justin was telling me that once he removes the nissan ecu from the harness then i have to buy a coolant gauge because it wont read. this doesnt make sense, but then it does. fill me in por favor.
