Engine Swaps For all your engine swap experiences, ideas, questions, & more..
The Official LS Swap Info/Questions Thread
Old Sep 25, 2012 | 02:34 PM
  #961
sh0rtys463's Avatar
sh0rtys463
Old Sep 29, 2012 | 08:13 AM
  #962
sidewaysracin's Avatar
sidewaysracin
So now that it runs, i got the exhaust done. The only issue is that it seemed to idle super high and was back firing really bad. My buddy brought iver his Tech2 scan tool and found out that it was reading the throttle at 99% open. Did some checking with the wires and found out that they wired the throttle position senser backwards..... So that adds another problem to their list.
Throttle position senser
Main power plug
Fuel pump relay
Fan relay
Ignition relay
Coil pack plugs
Now that i got to drive it i found that sikky shifter problem with poppin out of gears and my 3rd gears shift fork is ****ed.... Did anyine ever figure out a solution to the sikky shifter? Other then selling the sikky and going with a fueled racing kit...
Old Sep 29, 2012 | 06:12 PM
  #963
endless_summers's Avatar
endless_summers
Main power plug
Fuel pump relay
Fan relay
Ignition relay
Coil pack plugs
04.350z did some extensive work on his shifter. go here: https://my350z.com/forum/9846540-post199.html
Old Sep 30, 2012 | 12:38 PM
  #964
rhodesracer's Avatar
rhodesracer
Default 07 350Z with a F2 procharger is running
The ET Tuning 350Z comes to life and ran at VIR for it's first test. It did well with easy lap times coming in at 2.04, over 160 on the straights. A dialed back tune up is producing 700 wheel horsepower on 16 lbs boost. A little work containing the exhaust heat and we will be back out.
Attached Thumbnails The Official LS Swap Info/Questions Thread-z_car_iphone-004.jpg   The Official LS Swap Info/Questions Thread-z_car_iphone-026.jpg
Old Sep 30, 2012 | 01:30 PM
  #965
Royal_T's Avatar
Royal_T
^^^ fuuuuckkk!!!
Old Oct 2, 2012 | 01:04 PM
  #966
jomamahama's Avatar
jomamahama
how much harder will it be to have a shop swap in an auto transmission with these kits? What problems to deal with?
Old Oct 3, 2012 | 04:35 PM
  #967
04.350z's Avatar
04.350z
i have had alot of people ask about the shifter fix. i am the only one to have tried it so i cant gaurantee it will work. the only way is to try. i can have the same thing done to yours but its going to cost you $. and theres no guarantee it will work. also it will void any type of warranty from sikky.
Old Oct 3, 2012 | 05:51 PM
  #968
sh0rtys463's Avatar
sh0rtys463
Has anyone not had issues with the sikky shifter?
Old Oct 4, 2012 | 11:42 AM
  #969
nismo69's Avatar
nismo69
Someone should post a how to with a stand alone harness. Im getting close and was just looking at options for harness. It seems everyone sucks except for a stand alone. The chase bays is nice since its pug and play but not worth the headache. If it doesnt work.
Old Oct 4, 2012 | 12:13 PM
  #970
sh0rtys463's Avatar
sh0rtys463
Yeah not to mention the 5-6 months it may take to get it from ChaseBays
Old Oct 4, 2012 | 02:14 PM
  #971
sidewaysracin
The only thing i can see being a problem with your shifter fix, is that it wont be centered in the counsil. Sikky did say today that when they find a fix they will swap out the old shifters for people. Talked to Rich this morning about it all. Tried returning the kit... Sick of all the issues ive had with them.
Old Oct 4, 2012 | 04:28 PM
  #972
QTB's Avatar
QTB
Reposting this from where I posted at ls1tech.com
I have a T56 Magnum I've bolted up to a LS2 from a corvette with a ACT twin disc clutch. I bought a brand new CSC when I put it all together and I'm using a pair of stainless steel braided lines from a kit for this swap into a 350z from Sikky Mfg.
When I put all together I check the CSC face to clutch pressure plate and it was slightly off so I added a spacer behind the CSC and remeasured. It was then within spec. I've got it all bolted back up and went to bleed it tonight and it is dumping fluid all over.
What am i missing? This seems like a pretty simple concept but I've beat my head so much I know I'm missing something easy, which will now be hard since it's in the car.
Thanks....
Old Oct 4, 2012 | 08:43 PM
  #973
Brew_haha's Avatar
Brew_haha
Wiring in a stand alone harness isn't hard
Old Oct 4, 2012 | 10:51 PM
  #974
Quamen's Avatar
Quamen
Not possible to make a standalone how to. Each engine management will have different sensors and wire colors. My TEC GT can be wired multiple different ways (full sequential, batch, TBI and even secondary injection). However, when you choose your setup it becomes very straight forward to wire.
The only time that a standalone will be slightly more complicated is if you try using other sensors than the recommend one. On mine for example, I am using the recommended universal mag sensor where the stock LS crank sensor would be. However, I could have used the the stock C6 crank sensor (but not C5) by simply buying the sensor and pigtail connector and wiring a resistor in (critical step some might miss).
Old Oct 5, 2012 | 12:07 PM
  #975
sidewaysracin
Anyone looking for sikky 1 7/8 long tubes with a full 3in y pipe into a single muffler? For sale! Y pipe has a bung for a wideband. Drove for about half mile, now its all coming out. Pm me for questions.
Old Oct 6, 2012 | 07:02 AM
  #976
mhammel20's Avatar
mhammel20
pmd!
Old Oct 6, 2012 | 10:56 AM
  #977
sidewaysracin
I texted ya.
Old Oct 6, 2012 | 11:22 AM
  #978
mhammel20's Avatar
mhammel20
you did? havent gotte anything
I texted ya.
Old Oct 6, 2012 | 12:55 PM
  #979
Cass007's Avatar
Cass007
That would be me
Old Oct 6, 2012 | 02:41 PM
  #980
sidewaysracin
Pm'd ya
