Engine Swaps For all your engine swap experiences, ideas, questions, & more..
The Official LS Swap Info/Questions Thread
Old Sep 8, 2012 | 05:04 PM
  #921
Quamen's Avatar
Quamen
Very nice Logan! I have the street wheels on my Z right now so I will take some time tomorrow to put the slicks and skinnies on the G35X for reference. I will be sure to post a picture for you.
Old Sep 8, 2012 | 05:23 PM
  #922
Quamen's Avatar
Quamen
Thing is a beast and it isn't even tuned and doesn't have the nitrous on yet!!!
http://www.youtube.com/watch?v=2iAyd...ature=youtu.be
Old Sep 8, 2012 | 06:33 PM
  #923
jomamahama's Avatar
jomamahama
Any of you guys know if 180 degree headers will fit with a LS1 swapped G35 or 350Z?
I think they sound sick...
Old Sep 8, 2012 | 08:41 PM
  #924
Quamen's Avatar
Quamen
They will not fit.
Old Sep 8, 2012 | 08:49 PM
  #925
Chi-TownWarrior's Avatar
Chi-TownWarrior
Probably be easier to have a flat plane crank custom made.....But that's not all you'd need done for that to work.
Old Sep 9, 2012 | 04:56 AM
  #926
Quamen's Avatar
Quamen
Bottom line is that those headers in the pictures are designed for a transaxle... not a transmission.
Old Sep 9, 2012 | 01:09 PM
  #927
Brew_haha's Avatar
Brew_haha
Thanks in for the pics
Old Sep 11, 2012 | 08:50 AM
  #928
mhammel20's Avatar
mhammel20
subscribed.. i am currently in the process of doing an ls swap on my z as well
Old Sep 13, 2012 | 11:52 AM
  #929
sidewaysracin's Avatar
sidewaysracin
So question. With a chasebays harness do I still need to remove the VATS from the GM ecu? I wanna start the car and make sure everything is good before the tuner comes over. What's everyone done?
Old Sep 14, 2012 | 03:41 AM
  #930
04.350z's Avatar
04.350z
Made my own harness and removed vats
I can't imagine you wouldn't have to remove vats with a chase bays harness but could be wrong
Old Sep 14, 2012 | 07:36 PM
  #931
Quamen's Avatar
Quamen
Car weighes 2,768lbs in street trim! Race trim will be under 2,700 lbs!
Old Sep 15, 2012 | 11:24 PM
  #932
sidewaysracin
So I got a 98 vette ecu, and I have no spark and no fuel pump. What can I do. On the chasebays harness, do you need to hook up the 4 wires out of the bcm for water temp, mil light, vss, and the other one. Tryin to be this thing figured out... Can anyone help?
Old Sep 16, 2012 | 05:02 PM
  #933
sidewaysracin
So niw i have a ecu that has the vats deleted and a bunch more so it should work to start the car. I still have no spark and no fuel.. Theres no wire in the ecu connector for a crank positioning sensor power and my obd port dosent work. So i have no idea where to start with this thing. Any advice?
Old Sep 16, 2012 | 06:15 PM
  #934
Quamen's Avatar
Quamen
Dyno:
At The Track:
http://www.youtube.com/watch?v=TV0cI...ature=youtu.be
Old Sep 17, 2012 | 03:07 AM
  #935
endless_summers's Avatar
endless_summers
I am having the same issues. I am swapping an ls1 into a friends 240 and he has the chasebays plug and play harness. There's nothing we actually wired up. Just plugged everything in. Friday evening, I checked voltages on the ECU and long story short, every pin had 12v except for the 12v inputs with the key on. And this is why he does not have fuel or spark among other things. All the grounds are hot, with the ecu disconnected and the 12v inputs seem to be grounded. He sent his harness back to chasebays so they can check it out. Chasebays sent him a 2 day Fedex return label. They are taking care of it.
Old Sep 17, 2012 | 06:31 AM
  #936
sidewaysracin
This is starring to get old with fixing things that I shouldn't have to fix and losing money from cancelled appointments... Retarded......
Old Sep 17, 2012 | 07:12 AM
  #937
Quamen's Avatar
Quamen
Ditch your pre-made harness and wire it yourself or take it to shop that can do it for you. I don't care if it is Sikky, Hinson or Chase Bays they are all problematic.
I keep saying that people doing ths swap should just buy a standalone with its own harness. Way easier, cheaper and better performing.
Old Sep 17, 2012 | 09:46 AM
  #938
Royal_T's Avatar
Royal_T
Very nice Quamen..Car is a beast...
Okay boys and girls, I am about to get my custom exhaust made and was wondering if any of you guys would be interested in buying a exhaust that would bolt up to your longtube sikky headers. My Fab guy is going to make a jig for it so it should fit perfectly.
Old Sep 17, 2012 | 11:03 AM
  #939
Brew_haha's Avatar
Brew_haha
I went with a pre made harness from current performance.com. had to wire a couple of wires in but it actually works. sideways and endless I know it can be a pain getting ahold of someone at chasebays but you can call or shoot me a email. I have wiring diagrams that might can help and I'm familiar with the harness and the swap. 205-365-0091 or email me logandbrewer@gmail.com
Old Sep 17, 2012 | 04:56 PM
  #940
04.350z's Avatar
04.350z
Make your own. Then if it fails you can only blame yourself not others.
