Engine Swaps For all your engine swap experiences, ideas, questions, & more..
The Official LS Swap Info/Questions Thread
Old May 29, 2013 | 08:48 AM
  #1261
QTB's Avatar
QTB
Originally Posted by 2004Black350z
I wanted to be around the 10k range. Dam how does Dan at zfever charge 12K for the motor transfer labor functional gauges etc?
Classy?
HAHAH yeah we all wanted it to only be $10k. If you're looking for cheap 'go fast' just buy a corvette. I'm not a corvette person per say but you get a lot for your money. I have at least 4 people I go lapping or race with that have just given in and bought one. I hate to admit it but I'm tempted myself. Maybe once I crash the Z and it burns to the ground.
Old May 29, 2013 | 09:19 AM
  #1262
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Lmao. Well Idk bout a vette I was thinking new challenger srt 8
Old May 29, 2013 | 03:38 PM
  #1263
04.350z's Avatar
04.350z
I should a just bought a c6 vette I'd prolly be happier but having a ls6 350z is pretty fu$%$$# cool
Old May 29, 2013 | 04:48 PM
  #1264
2004Black350z
Exhaust Whore
I understand completely!!! THats the main reason bc of the passion I have for the Z im just DONE with the power. I almost feel im to old bc all the local ricer teenagers that have them. But im doing the math of what I have now and what I could sell the counter cost of Ls. Then I think if im going in mine as well go LS2 bc of the extra power. Ls1s are quick bt not uber fast. Headers and exhaust 2500 easy. engine 400$. Trans with clutch flywheel 1k. Then AGAIN take EVERYTHING off wheels suspension sell all turn car stock trade in for around 8k towards a new SRT8 idkwtf to do. Z is paid off which is nice but done with this power. EVEN though i drive 10 miles a day to work lol
Old May 29, 2013 | 08:10 PM
  #1265
Quamen's Avatar
Quamen
Yeah but a Challenger SRT8 has a curb weight of 4,170lbs which is a tank compared to a Z with an LS. You could put a stock LS1 in the Z and walk over the SRT8 on the straights and the curves.
When comparing an LS1 to an LS2 I would take into consideration the money saved by purchasing and LS1 and then putting that towards mods like intake and cam.
Old May 30, 2013 | 05:03 AM
  #1266
2004Black350z
Exhaust Whore
Thanks for response quamen. I think your right as well. I just don't want to start then get nickled and dimed to death.
Old May 30, 2013 | 03:26 PM
  #1267
Classy's Avatar
Classy
Here are my 2 cents for you 2004, I sold my 350z for a challenger r/t with a manual, yes it is a heavy ****, BUT! It does have an IRS, handles pretty well for a stock suspension, and the 5.7 has a healthy amount of power, in about every test ever done comparing the challenger to the mustang and camero it has lost, but I bought it to have a stick, 2 door fit 3 kids in the back, and a V8, I even get better gas mileage than my 350z. I haven't gone mod crazy, I just made an intake, put on a JBA cat back and did a skip shift eliminator. I really love the car and even though it wasn't as nimble as my 350z on coilovers and about every suspension peice installed (I don't remember how it handled on a stock suspension) and it isn't as fast as my built N/A V6, but it is a heavy **** too... I will let you know how I like long tubes, mid pipes a tune and possibly a cam feels when I get there this summer, but this car is my DD just as my 350z was (just way more reliable) if you chose the srt8, it is a good power jump, a better suspension, brembo brakes and super nice interior. What ever you decide I hope you the best, PM me if you want to know more.
Old May 31, 2013 | 12:56 PM
  #1268
QTB's Avatar
QTB
I get a little grumpy with myself for having done this swap, then I goto the race track, win my class and then fall in love with this car all over again. The bottom line is the Z chassis is amazing, with a decent amount of power and a little 'know how' it's simply ridiculous at the track.
Old May 31, 2013 | 06:05 PM
  #1269
sidewaysracin's Avatar
sidewaysracin
Z fever price is also you provide your our engine an Trans. I think right now I'm up to about $17k with the fully built engine/ Trans/ an turbo setup. You can do it on a budget but ya gotta be good at findif deals. I was doing good with mine until I had to built my Trans and while I was at throwing the turbo in.
Old Jun 1, 2013 | 11:06 AM
  #1270
2004Black350z
Exhaust Whore
Nope that includes motor and trans
Old Jun 2, 2013 | 10:41 PM
  #1271
sidewaysracin
That's not too bad then.
Old Jun 3, 2013 | 05:33 AM
  #1272
stealthz's Avatar
stealthz
I know this was stated this in an older post:
"All you have to do is retro fit the stock Z oil pressure sensor and coolant sensor to the LS motor and install an aftermarket tachometer such as the Speedhut gauge and you are good to go. Wire the LS motor up with the stock GM harness and ECU and call it done. If you use an aftermarket tachometer, there is nothing about an LS swap that requires the Nissan and GM electronics to communicate. "
Is there an actual break down that someone has of the wiring? Not using a standalone.
Is it possible to have the Z running on just the Ls ecu. So the Z ecu doesn't even have to be equipped? So running the car with every sensor including evap hooked up on the motor and working properly as if it were a stock Ls and only have to disable the vats system on the Ls ecu. Will the obd2 diagnostic port still work, and the car have no check engine lights? I don't mind the speedhut tach and the ac issues.
Old Jun 3, 2013 | 10:21 AM
  #1273
04.350z's Avatar
04.350z
Ugh....
Old Jun 3, 2013 | 05:22 PM
  #1274
Quamen's Avatar
Quamen
If you remove the stock Z ECU chances are there will be significant amount of other items on the car that do not work anymore as the CAN system is deeply integrated in the car. That is not to say that you can't find a way to have an OBD-II for just the LS motor, but you will still need some of the stock electronics retained.
Old Jun 4, 2013 | 07:07 PM
  #1275
andz33's Avatar
andz33
What spring rate is everyone running that has done the swap?
Old Jun 5, 2013 | 08:15 PM
  #1276
stealthz's Avatar
stealthz
Thx Quamen. On another note, since I haven't seen the wiring breakdown involved in doing this swap. What exactly are companies like sikky's wiring service merging together. Is there a diagram of the wire breakdown using both Ls and Vq ecu's? Or even a how-to on the wiring aspect? I know you mentioned it being basic and all, but from all the reading I've done it seems like a good number of people still ask about the wiring. And there's no real breakdown of it...
Old Jun 6, 2013 | 06:06 PM
  #1277
04.350z's Avatar
04.350z
There's no break down because..
Ain't no.one.got time for that
Old Jun 6, 2013 | 08:32 PM
  #1278
Quamen's Avatar
Quamen
There are three main reasons why you will most likely not see a breakdown. The first is that every installation will be different depending on the end user's need (i.e. A/C, Electronic TB, Auto Trans, etc.). The second is that a company that offers this service will have a significant amount of time vested and will not give the information for free or it defeats the purpose. The third is that an individual, such as myself that does it on their own, will not have incentive to go thru the hassle of documenting everything unless they have lots of time on their hands.
Old Jun 7, 2013 | 03:15 AM
  #1279
Lightning Guy's Avatar
Lightning Guy
Well my swap has officially just started.
My goals: A fast road race car. Those that already know me know my Z was pretty quick and very light. So this is going to be a very minimal fluff build. Tach, oil and water sensors, AFR gauge, that's about it. While we are at it we are going to convert the car to RHD, since there is not much left other than a rack, why not.
Things I currently have:
LS3 - stock
T101 tranny
DXD clutch/flywheel
SFI bell housing
Brew-haha's old chase bay harness
Things I'm fairly certain on:
Tilton 72-602 brake/clutch pedal
Canton 12-270A oil pan
Dry Sump pump and accessories
DSS drive shaft
Things I need help with:
gas pedal (cable)
I have a lead on a RHD Z33 steering rack, but was considering a manual RHD or MR2 RHD rack.
Old Jun 12, 2013 | 07:52 PM
  #1280
350Z_Al's Avatar
350Z_Al
Those who are still using the 350Z ECU for sensors/gauges are you guys getting to "dumbify" and reflash the ECU to delete all the un needed crap?
