Engine Swaps For all your engine swap experiences, ideas, questions, & more..
LS1 Drift Build 'Nuff Said'
Old Apr 12, 2013 | 05:10 PM
  #581
litoflow's Avatar
litoflow
^^cant wait to see it done already my friend. Good Stuff! always building rad stuff for this car..
Old Apr 13, 2013 | 10:29 AM
  #582
QuintonC's Avatar
QuintonC
Don't know if you know this yet, or not.. but uhhh, the weekend is here \_(o.O)_/
Old Apr 14, 2013 | 04:06 PM
  #583
Classy's Avatar
Classy
7pm on Sunday....
Old Apr 14, 2013 | 04:54 PM
  #584
Quamen's Avatar
Quamen
8pm central time sunday..
Old Apr 14, 2013 | 05:02 PM
  #585
Royal_T's Avatar
Royal_T
Okay finally a good update, been kind of crazy over here with the move to the new house and ordering a lot of fittings and hoses. But here we are so lets get this party started.
Lets start this off with a good beer. Since I have put beer a side for a couple of months (I know I'm crazy right) to get my body back into shape. Going to post up some picks from my good friend Drew. he has a Instagram posting nothing but the best crafted beers so check it out.
I begin this update with a little trip to Houston to pick up my built T56 tranny. Got all the good ready for the trip for me and the lil man.
I acquired the transmission from my good friend Evan. He owns D3 Performance Engineering and they do so sick work.. Only the best, they were the ones that tuned the Hennessy lotus. So needless to say they will be the ones that tune my car.
I also purchased some goodies for the T56. Monster Clutch was a no brainier and they were well helpful when deciding which clutch to go with.
I went with there 11" clutch with pressure plate and light weight flywheel package.
Love the level of detail; just in making sure the customer package includes everything.
Also picked up my Saiko Michi Dual Catch can..
Love the look of this thing
Okay lets start some installs.. I picked up a new Slave Cylinder. and a backup you never know.
But first I have to switch out the lines for my Chase Bays lines..
yup undo this....
removed
new bleeder line about to get installed
I think thats about right
Tighten that **** up with some 15mm
Next is the clutch line itself
have to removed this, but what there is no screw
You have to knock out this pin
yup
Once the pin is knocked out the fitting should just pop off
view of the pin
Install the new line and insert the pin.. Hammer that sucker in..
BAM!! looks like money
Time to install
You know me only the best.. ARP bolts...
Next on the list is to remove this shifter level for a GTO one.
This can show you the difference in size between the two.
Look came to help out dad.. Thanks bud
Again this has a pin that you have to remove and reinstall
Now I could install my Sikky shifter
Also drilled and tapped for my bleeder line.. Installed and ready to rock
So removed the engine to start on the T56 install
Start out by removing the old pilot bearing.. I rented this blind puller to get the job done..
Let's do work.. Took me about 2 min to remove.
Out
View of the old vs New..
tap that sucker back in..
installed
Flywheel going on.. Again ARP bolts are needed
Clutch and pressure plate getting installed.. The green monster
I also re-taped some of the holes on the engine so the bolt holes would not striped. I used Hilico to get the job done.
Back in you go.. And yes I removed the shifter
Old Apr 14, 2013 | 05:05 PM
  #586
Royal_T's Avatar
Royal_T
Next I had to tackle the fuel setup. Went with Aeromotive 340 pump and also hit up CJM for their OEM Pump To -6AN and Return Fuel Correction Kit..
Took out the old fuel pump unit
Take it apart
Pop this bottom cap off that holds the fuel pump in..
Remove the sensor
Out!!
Side by side view
Place rubber cap
Install the filter bag (I think that is the name oh well)
Place back in
You have to shave done some of the cap to make it fit.
Drill this sucker, if not you will have a rough idle..
Pop back in
Time to install the return line.. Drill whole
install fitting
Another view from underneath
install this guy and make sure all the seals are in place
Install line to it
Run the line to the top
Next install the OEM Pump To -6AN..
Complete!! Now just place back in the car
So painted my Coolant tank
And reinstalled.. I think it looks 10times better
Also while the engine was out I installed my new fittings for my power steering rack
Also started to install my Fuel Pump Regulator
  #587
Royal_T's Avatar
Royal_T
Installed
Also installed my bulkhead for my oil line to my Accusump
View of all of them installed
Also started getting my fittings and lines in.. This is what the color scheme is going to look like.. Keep it classy
I also picked up a new steering wheel.. Only gloves are going to touch this thing
Time to install the catch can since the motor is back in..
Bracket installed
nice and clean..
This is how I will route the catch can
I picked up these sick locking bolts for my headers so they will not leak on me.
Now here is a pic of them installed BUT... this one I took a pick of had to be fixed,, as you can see it would not be doing any thing if it was not at the 11 position. But I liked this pick so posting it.....lol
While I was waiting on hoses and fittings. George sent me the kit we have been working on for the dual caliper setup. This thing is top notch..
Bracket bolts to your hub and actually pushes your wheel out another 4mm. So def have to take note of that when getting my 18s for drifting.
Everything is included
So these are going to go into production soon but George sent out a small batch to some people for testing. Once that is all said and done he will start selling them like he does the S13/S14 brackets on zilvia
So for now I will only be using the OEM iron calipers.. Still bouncing around which calipers I want to run.
Hub removed
Sorry to say but you will loose the OEM e-brake with this setup. But he is working on another kit to keep it. But for me BecauseRaceCar...lol
install bracket
BAM installed and ready to rock..
So while I was still waiting for some parts.. Lets mount some tires
Wheel specs are 19x11 0 19x13-20.. Now these are not my drifting wheels just marketing wheels.. So might be selling them after photo shoot.
Feel sorry for him..lol
11s were easy
Cheetah time
POW!!! mounting 275/35 on the 13s
11 stretched on 245/35
13s looking damn good
Perfect stretch
Back home and looking good
test fit. Over fenders are replacing the OEM ones so it will sit nicely..
Another view
Got my Fan shroud from Blake (the one with the sick FC build) thanks buddy..
Painted it crinkle black and mounted my fans
Mounted up
Looking good..
Picked up some tools for the AN fest we are about to get in to..
Also picked up this to make install easier
Got hoses?
fittings laid out and all labeled so I know what goes where.. Lets do this
Install begins..
Good thing I have these
Looking good.. Now lets run fuel lines
I ran them were the old fuel lines went. But thinking about putting a plate over them so nothing hits them.. Thought?
Fuel setup complete
Bottom Radiator hose
My front coolant lines
They Tee off right here and head to the coolant tank
The driver rear coolant line
Passenger coolant line and some of the fuel lines
Oh yeah all hooked up
My Dual Catch can lines ran
Found these sick fittings that match my AN ones perfectly
Another pic of the lines ran to the expansion tank
Line ran from the Radiator to the Coolant tank
Big *** Radiator lines
Mounted my oil filter in the back near the brakes.. Clean and out of the way
A full pic off everything ran.. Looking good I must say
All of it is coming together
I also mounted up my Status Racing seat to check the fit.. Looks good
This view is so sick.. Next is to install my Carbon Fiber door panels and floor boards... Should look sick when done
God I can't wait to rip on you.. oh yes
I also got some goods for out side the car..
Love this hood. went with the 07 cause I love that hump. I will color match this hood and leave the vents CF..
I also have this Coming in the mail TS diffuser and some new side skirts..
So that is it for now.. I should be getting some stuff in the mail and the next phase is exhaust so should be heading out that way in a couple of weeks..
Also I will post amount later.. Thanks guys
Old Apr 14, 2013 | 08:15 PM
  #588
mvthree50's Avatar
mvthree50
Soo sick
Old Apr 15, 2013 | 03:36 AM
  #589
Quamen's Avatar
Quamen
Very nice!
Old Apr 15, 2013 | 10:21 AM
  #590
quiksilver38's Avatar
quiksilver38
hhhhhhhhhnnnnnnnnnnnnnnnnnggggggggggggggggggggggg
Old Apr 15, 2013 | 05:30 PM
  #591
FWM69's Avatar
FWM69
Damn dude!!! If I'm ever in San Antonio I'd love to stop by and check this thing out!!
Old Apr 15, 2013 | 05:55 PM
  #592
NinerZ's Avatar
NinerZ
I will tell you what, I started reading this thread about a week ago. I figured surely he has finished this project. After a couple of sittings trying to read through it I found out your still working on it. I am glad I get to witness this truly badass masterpiece being finished. Awesome work, inspiring!! Can't wait for the results!
Old Apr 15, 2013 | 06:52 PM
  #593
Classy's Avatar
Classy
Well, I got my quarterly Royal T build fix, see you this summer!
Old Apr 16, 2013 | 12:56 AM
  #594
04.350z's Avatar
04.350z
Definitely build a plate to cover the fuel lines i utilized the factory hard line and added a new hard line when i went to a return system vs using braided line seemed more oem and safer in my eyes and i used braided lines to go from the hard line to the different areas of the system. looks great if your belt doesn't squeak when you start her up pm me a mod list for your accessory driveline
Old Apr 16, 2013 | 03:32 AM
  #595
Quamen's Avatar
Quamen
Braided should be safer than hardline since it will be less affected by impact. I ran my braided line on my Z just like Royal T and we do in our Porsche as well with zero issue.
Old Apr 16, 2013 | 06:35 AM
  #596
04.350z's Avatar
04.350z
Well that being said the braided lines are much larger in diameter so less clearance.
The stock lines are protected by the frame rail
That being said your are also right on them being affected by a impact
Old Apr 16, 2013 | 07:03 AM
  #597
stein350z's Avatar
stein350z
let me say....
Old Apr 16, 2013 | 07:47 AM
  #598
SirMichael's Avatar
SirMichael
Looks amazing. Been watching this build from the beginning can't wait to see it complete.
Old Apr 16, 2013 | 10:06 AM
  #599
Royal_T's Avatar
Royal_T
Originally Posted by mvthree50
Soo sick
Thanks bro
Originally Posted by Quamen
Very nice!
Thanks
Thanks man and PM me if you are ever in San Antonio. If I am free sure.
Thanks man, Yeah this bad boy is taking me some time. But keep telling myself it is well worth the wait.. So grab some popcorn and enjoy it until the end. lol
hahahaha well lets hope I dont have another update until the summer. Working on stuff now to give you guys another update in a week or so.
Let me ask you something how did you remove the OEM lines from the damn fuel tank. there is one section I could not remove because of the gas tank so said **** it and left a bout a 3-5" line there.
I totally agree with you. I know I should be fine but since I run a little lower then most I think I might just at a skid plate just for my comfort.. doesn't hurt
Originally Posted by stein350z
let me say....
hahahahaha that's what I'm talking about
Thanks man, should be completed soon
Again thanks everyone for the kind words. I know the progress has been slow but we will get there. And wants its done, nonstop burnouts going sideways.. oh yeah!!
Old Apr 19, 2013 | 12:19 PM
  #600
username668's Avatar
username668
