Engine Swaps For all your engine swap experiences, ideas, questions, & more..
My 2JZ-GTE VVTI swap thread.
Old Aug 21, 2015 | 01:36 PM
  #421
midz350's Avatar
midz350
Originally Posted by IanP
Did you get the shifter relocater installed?
how was the fitment?
The engine and tranny still out of the car, but as per my calculation it should be perfect fit.
Old Aug 24, 2015 | 11:47 AM
  #422
midz350's Avatar
midz350
Small peek:
Old Aug 24, 2015 | 08:58 PM
  #423
Resmarted's Avatar
Resmarted
Doesn't look like a stock part rebuild.
You'll now officially hold more power than just about every built vq35 on here.
Old Aug 26, 2015 | 08:49 PM
  #424
midz350's Avatar
midz350
Old Sep 5, 2015 | 09:42 AM
  #425
midz350's Avatar
midz350
Cams are in and head is bolted on.
Its official, I have the worst luck when it comes to building cars. This is just an example:
Not sure what happened here "valve cover:
From broken timing gear:
And we are having a hard time with the Collins adapter. When ever we bolt the tranny its not lining up with the engine. The tranny is angled a little to the driver side, so the shifter is not lining up. Already sent him an email and still waiting for his response.
Old Sep 5, 2015 | 11:41 AM
  #426
Resmarted's Avatar
Resmarted
The adapter sucks, but the timing gear isnt too horrible. There are millions out there for the 2j. Just get another.
Valve cover you could just repair. Hell even jb weld would do the job. Get it working then if you want to replace it with a nice one. There could be a flaw in the cover and the metal fatigued especially if someone over tightened it or didnt do the correct bolt down order.
As for the adapter, get a micrometer and check all the surfaces to be flat and true.
I've had to replace all sorts of things you arent supposed to need to on my build. That's just how things are when you take them apart. And mine was expensive too. Just remember the more times you build things, the more times these little things can and will happen. I've never once seen an engine swap or rebuild go completely smoothly.
Old Oct 29, 2015 | 08:29 AM
  #427
midz350's Avatar
midz350
Small update,
We managed to make the adaptor to fit, but couldn't find the FW ARP bolts. After talking to some other customers turns out their kits were shipped also without the bolts too.
I contacted Brett, he said I have to pay for new ones which I didn't mind. Later he told me he is busy and I should find them somewhere else!!!
Anyway, I ordered them from Summit Racing and ordered the Mishimoto radiator + fan and shroud kit from CZP.
Old Oct 29, 2015 | 07:48 PM
  #428
Link85x's Avatar
Link85x
Nice! New here, been following the thread for a long time. Hope it all goes well. Is the shifter location close with the Collins Adapter?
Old Oct 30, 2015 | 03:44 AM
  #429
midz350's Avatar
midz350
I notice that If you want the shifter to sit centered just like stock, you have to fab a custom front support or run pusher fans.
Old Oct 30, 2015 | 06:19 AM
  #430
Link85x's Avatar
Link85x
How much further back does it sit the way you have it set up?
Old Oct 30, 2015 | 06:31 AM
  #431
midz350's Avatar
midz350
I have a custom front support and custom engine mounts. These mounts are designed with the ability to move the engine back/front 1 inch either way.
I want to push it forward to center the shifter and the shop want to push it back because of center of gravity and see if we can use the light blastic OEM custom front support
Once we have the engine back in and find the sweet spot will post pics.
Old Oct 30, 2015 | 06:46 AM
  #432
Link85x's Avatar
Link85x
Nice, would definitely like to see how that fits.
Old Nov 22, 2015 | 09:11 PM
  #433
midz350's Avatar
midz350
The car is running again
Had to redo the wiring just to make sure.
The shop pushed the engine back more, so they will take it today to fix the downpipe and exhaust.
They said they had to shorten the Hoke shifter more, but I don't know how they did it. It set little to the back and to the driver side.
And received the Mishimoto radiator and fans.
Old Nov 25, 2015 | 10:23 AM
  #434
Link85x's Avatar
Link85x
Jesus! Look at all those WIRES! Lol. Self custom harness or something like chase bays or tweaked performance?
Old Nov 26, 2015 | 07:24 AM
  #435
midz350's Avatar
midz350
It's a custom harness. The one's you mentioned are not plug and play,so they're useless for their prices.
Old Dec 12, 2015 | 11:03 AM
  #436
midz350's Avatar
midz350
99% Complete. Just need to wire the OEM water temp gauge and make the A/C lines and take it to install the Whiteline bushings.
Old Dec 12, 2015 | 04:38 PM
  #437
Classy's Avatar
Classy
You are going to wash the years of dust off that beast soon, I hope you enjoy it
Old Dec 13, 2015 | 03:09 AM
  #438
Resmarted's Avatar
Resmarted
Sweet
That car is going to be nuts.
Take some videos for us!
Old Dec 13, 2015 | 05:44 AM
  #439
midz350's Avatar
midz350
Thanks.
Originally Posted by Resmarted
Sweet
I haven't driven it yet and already start think about changing the turbo, clutch, fuel system and crank pulley and go for 1000whp
But I should spend the money on a new daily drive instead. Considering a 2011-12 Infiniti M56S or a 2009-10 M3 E92. Still haven't decided yet.
Old Dec 13, 2015 | 09:31 PM
  #440
Resmarted's Avatar
Resmarted
Thanks.
Youve got a 2jz now! Is the engine really setup that aggressively with tolerances that you need a seperate daily?
I would probably be beating on that engine. The ratios are very good in it for longevity
