Engine Swaps For all your engine swap experiences, ideas, questions, & more..
My 2jz swap
Old Feb 21, 2018 | 05:48 PM
  #101
chase z's Avatar
chase z
New wheels and rubbers . Now lets see if i can put the power to the road
Old Mar 4, 2018 | 08:26 AM
  #102
chase z's Avatar
chase z
8x15 5.5 offset rims with 275/60s and a new rad with out the messed up core
Old Mar 11, 2018 | 06:41 PM
  #103
chase z's Avatar
chase z
All welded up and pressure tested to 20psi.
Allso got the new fuel filter installed and moved the fpr.
Old Mar 12, 2018 | 04:43 AM
  #104
BluestreamDE's Avatar
BluestreamDE
Looking good, it's coming along nicely!
Old Mar 12, 2018 | 09:13 AM
  #105
chase z's Avatar
chase z
Thanks. Im hoping to get it all together this weekend and do a test drive if all is fine, i will set up a appointment to get it tuned.
Old Mar 17, 2018 | 03:26 PM
  #106
chase z's Avatar
chase z
Intercooler remounted and made a oil catch can aswell
Old Mar 18, 2018 | 03:10 PM
  #107
chase z's Avatar
chase z
An lines cut to size and installed .
and a quick start up
Old Mar 18, 2018 | 03:19 PM
  #108
BluestreamDE
Congrats, it's alive. Looks like it is idling well. Did you do a test drive?
Old Mar 18, 2018 | 06:23 PM
  #109
chase z's Avatar
chase z
Na i didnt have time. I will tomorrow adfter i buttion everthing up.
Old Mar 26, 2018 | 04:08 AM
  #110
chase z's Avatar
chase z
Took the car out a few times this last weekned trying to keep the boost down to wg spring only 14lbs ,the lowest i can keep it down to constantly is 20lbs so looks like my low boost will be 20lbs .
Old Apr 19, 2018 | 06:40 PM
  #111
chase z's Avatar
chase z
update.
i have my dynotune this Saturday 21st. I will post a video and graph as long as it doesint blow up.
Old Apr 20, 2018 | 04:26 AM
  #112
BluestreamDE
Good luck! It's a 2J, you will make good power.
Old Apr 21, 2018 | 06:10 PM
  #113
chase z's Avatar
chase z
thanks .
Old Apr 21, 2018 | 06:27 PM
  #114
chase z's Avatar
chase z
So went to the dyno today spent 7 hours there had a few wire or ecu gremlins that i have to track down but i did solve my over boosting/ not boost control. At 11psi base gate pressure it made 443hp . Maxed out my boost solenoid at 24 psi it made 638hp 519tq. Once the wiring gremlins are sorted i will go back and with a bigger base spring for the gate and turn it up. Still lots of power left on the table
Old Apr 21, 2018 | 08:03 PM
  #115
bealljk's Avatar
bealljk
that's awesome congrats on the dyno & the numbers!
I'm happy to hear that I'm not the only one that has wiring issues on the dyno...
Old Apr 23, 2018 | 08:49 AM
  #116
chase z's Avatar
chase z
Thanks man.
yea once get all the little things fixed i will go back and add the rest of the boost in maybe 16psi more
Old Apr 23, 2018 | 06:24 PM
  #117
bealljk's Avatar
bealljk
you're going to push it to 40psi?
Old Apr 23, 2018 | 06:26 PM
  #118
chase z's Avatar
chase z
if it will make that much probably.
Old Apr 23, 2018 | 06:34 PM
  #119
bealljk's Avatar
bealljk
atta boy, atta kid!
Old Apr 24, 2018 | 11:07 AM
  #120
Conway_160's Avatar
Conway_160
Is 40psi worth it according to your comprosser map? Is your FMIC big enough to handle the extra heat created by the extra boost?
