Engine Swaps For all your engine swap experiences, ideas, questions, & more..
My 2jz swap
Old Apr 24, 2018 | 12:31 PM
  #121
chase z's Avatar
chase z
Originally Posted by Conway_160
Is 40psi worth it according to your comprosser map? Is your FMIC big enough to handle the extra heat created by the extra boost?
the inercooler should handle 850- 900
if my intake temps start getting to outrageous i will upgrade to a bigger one.
Old Apr 24, 2018 | 02:55 PM
  #122
chase z's Avatar
chase z
i still dont understand the math to read a compressor map
Old Apr 24, 2018 | 04:07 PM
  #123
bealljk's Avatar
bealljk
Start on the X-axis ... at the 77% efficiency oval (that center island) you can move ~50 to ~55 lbs/min with a (look at the Y-axis) pressure ratio of ~2.2:1.
your pressure ratio is your boost pressure divided atmospheric pressure ... at sea level it's 14.7psi.
At your turbos peak efficiency you can move ~50 to ~55 cfm at ~30 to ~32psi ...
You can push the turbo harder to 40-42psi (pressure ratio of 3:1) and move ~60lbs/min of air but you're decreasing your turbos efficiency, adding heat, spinning the blower harder, etc.
I love the adage that boost pressure does not equal air flow
this is how I understand a compressor map but I'd love to hear more insight from members with more FI experience than myself.
Old Apr 24, 2018 | 04:40 PM
  #124
chase z's Avatar
chase z
if i under stand that right how would i have made 630 wheel at 24psi if the peck efficiency is at 30 32 flowing only 55 cfm that would only be about 500whp wouldn't it
Old Apr 24, 2018 | 05:00 PM
  #125
bealljk's Avatar
bealljk
your turbo was operating under its optimal efficiency.
I'm not sure how to correlate your whp to a flow rate of a blower.
Youd have to really dig down and factor in your drive train losses/losses on the dyno/the differences between the compressor maps optimal operating environment vs. what the car was tested at to get a link between your peak efficiency and your dyno-gauged hp measurement.
Old May 1, 2018 | 08:24 AM
  #126
chase z's Avatar
chase z
Working on the bumper, trying to decide what to do with the open space left in the grill. To make a duct directing the air to the intercooler or use mesh.
Old May 2, 2018 | 05:33 AM
  #127
achampagne's Avatar
achampagne
a duct would look awesome
Old May 2, 2018 | 10:29 AM
  #128
BluestreamDE's Avatar
BluestreamDE
Nah just get a bigger intercooler
Old May 2, 2018 | 12:41 PM
  #129
chase z's Avatar
chase z
thats what i was thinking i might just leave it open for when i upgrade
Old May 2, 2018 | 12:42 PM
  #130
chase z's Avatar
chase z
Old May 2, 2018 | 01:13 PM
  #131
BluestreamDE
A bigger, better quality intercooler will net you more power as well to keep AITs down especially if you wanna push 40psi with your 2J.
I have a Treadstone TR1245 and I love it!
Old May 2, 2018 | 04:50 PM
  #132
chase z's Avatar
chase z
yea i was looking at the big treadstone intercoolers.
the one i have is 4in thick.
Old May 3, 2018 | 03:12 AM
  #133
Conway_160's Avatar
Conway_160
Remember air will take the path of least resistance, so instead of all the air going through the intercooler some will go around it. I would either find a way to close the gaps or get a bigger fmic. Just my .02 though.
Old May 22, 2018 | 03:01 PM
  #134
doyle4281's Avatar
doyle4281
Great effort man. Were you able to get a functioning tach and speedo? Also, what did you come up with for the throttle cable?
Old May 26, 2018 | 06:04 AM
  #135
chase z's Avatar
chase z
The speedo works with out any modifying. I used a canbus gauge for the tac. Perfect tuning gauge. The tc is a off the shelf autozone cable
Old Jun 12, 2018 | 03:30 PM
  #136
chase z's Avatar
chase z
Need help deciding what front bumper cover to get the oem one i have will be to time consuming to fix. So im in the market for a new one
Old Jun 25, 2018 | 04:05 AM
  #137
chase z's Avatar
chase z
new built block with 10.1 compression
ordering all the little parts so i can swap it over in a few weeks.
Old Jun 26, 2018 | 02:51 AM
  #138
Conway_160's Avatar
Conway_160
SEXY!
Old Jun 26, 2018 | 05:47 PM
  #139
chase z's Avatar
chase z
SEXY!
thanks
Old Jul 5, 2018 | 02:38 PM
  #140
chase z's Avatar
chase z
Got a few goodies in the mail today
