Engine Intakes, Exhausts, Clutches, Turbos, etc...
Mazworx | VQ/VR Sleeved & Built Engines
Old Jul 27, 2011 | 10:52 AM
mazworxracing's Avatar
mazworxracing
Vendor - Former Vendor
Default Mazworx | VQ/VR Sleeved & Built Engines
We here at Mazworx are world renowned for our huge horsepower SR20's. We have now branched out to create the best engine program for the VQ/VR engines. We are a fully capable machine & fabrication shop located in Orlando, FL. Utilizing our CNC machine capabilites, we can ensure you will always get the best quality work from us.
As to welcome ourselves into the my350z forum and to the members, we will start by offering our sleeved engine, ready for assembly package.
In this package, you will need to send us your block. We will prepare the block by de-plugging all the oil/water passages, hot tank, blast, hot tank the block. Then using our cnc machine, we will machine your block to perfect tolerances for the sleeve install. Once we install the sleeves, we will bore and hone using our billet torque plate to your piston specifications. We will also provide our proven "step deck" process to ensure proper gasket sealing under extreme boost conditions. Next we will install ARP main studs and do a proper line hone on the engine to make sure you have the perfect bearing clearances. After all the machining is complete, we will install all new freeze plugs into the engine, and properly measure the engine completely so when you get it back, all you have to do is install your rotating assembly. If you do not feel like installing your rotating assembly, we can do that for you also. Here below revised is the list of products and services included in the prepped block.
Darton MID Sleeve Kit
ARP Main Studs
Clean r/r oil ports
Sleeve install
Bore/Hone Cylinders w/torque plate
Resize Line Bore
Step Deck block.
Price for this block (does not include core charge) is $3029.00 for all VQ engines.
If you require a fully assembled block or engine, we can provide the services also.
We are so capable of doing fully built cylinder heads. You can check out this thread for some descriptions of our work.
https://my350z.com/forum/forced-indu...ine-build.html
Please inquire by:
Email: sales@mazworx.com
AOL IM: mazworxsales
MSN Messenger: sales@mazworx.com
Facebook: Mazworx Manufacturing
Website: www.mazworx.com
Old Aug 1, 2011 | 08:52 AM
mazworxracing
PM's replied Thanks!
Old Aug 1, 2011 | 03:14 PM
importdps's Avatar
importdps
These guys helped us break 7's with our Sleeved SR20DET block. The real hardcore nissan guys should use them hands down!
Old Aug 3, 2011 | 05:27 AM
mazworxracing
Congrats! And thanks for the compliments.
Old Aug 9, 2011 | 07:56 AM
mazworxracing
Old Aug 17, 2011 | 01:30 PM
mazworxracing
Old Aug 22, 2011 | 12:11 PM
mazworxracing
Old Aug 23, 2011 | 12:55 PM
mazworxracing
Old Aug 29, 2011 | 08:04 AM
mazworxracing
Old Sep 21, 2011 | 07:34 AM
mazworxracing
Old Oct 14, 2011 | 11:57 AM
mazworxracing
Old Nov 4, 2011 | 12:00 PM
mazworxracing
Old Nov 7, 2011 | 01:41 PM
mazworxracing
Old Nov 17, 2011 | 01:42 PM
mazworxracing
Old Nov 22, 2011 | 10:24 AM
mazworxracing
Old Feb 1, 2012 | 01:58 PM
mazworxracing
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
