foglights? yay or nay.
Old Nov 23, 2002 | 10:53 PM
ares's Avatar
ares
Veteran
Default foglights? yay or nay.
I got a set of PIAA 1900x fog lights that I kept off my last car. they are sweet as hell and have much the same color as the HIDs.
but I dont know where to put them. I was thinking of behind the grill and let them shine through, but I donno... Im not sure theres anything back there to even mount them too.
anyone installed foglights into it yet?
and yeah Im aware they arent needed with HID, but I have them just lieing around. so cant hurt to consider it.
Old Nov 24, 2002 | 04:43 AM
Traffic's Avatar
Traffic
Why not sell them on eBay? Then you could take the proceeds and buy the clear side finisher, or a new shifter or something.
Old Nov 24, 2002 | 04:52 AM
zcar70's Avatar
zcar70
Thumbs down NAY !
You don't need them, where would you put them, it would ruin the look of the car.
Sell 'em and get another toy!
FWIW
Old Nov 24, 2002 | 07:27 AM
ChinaClipper's Avatar
ChinaClipper
Thumbs down
Big thumbs down on foglights!
Old Nov 24, 2002 | 08:44 AM
EnthuZ's Avatar
EnthuZ
Yay...go for it.
I'm looking into mounting some fog lights in the grill area. The outer portions that are already blanked off should be an ideal location. Too bad the grill itself is molded with the whole nose. While I was washing my Z a few days ago, I noticed that the flat panels were loose......held in with snap-clips? I gotta get some low ramps and check out a solid mounting point. I don't trust sticky mounting tape.....
Old Nov 24, 2002 | 09:23 AM
zpeedDemon's Avatar
zpeedDemon
I want to see a 350Z with fog lights installed myself. Just wondering how it will look like. If you guys have any pics of your 350Z with fog lights installed plz post them here so everyone can take a look at them. I was thinking maybe a small round type of fog lights so it wont be too intrusive.
Old Nov 24, 2002 | 10:28 AM
zeeing's Avatar
zeeing
I installed PIAA 2100 Extreme white and this is my report:
1. If you are choosing quality brands it is impossible to adequately install without cutting parts of the grill off.
2. They absolutely complement HID in foggy conditions. Fog lights have a much wider and diffused light pattern which helps “cut” through the fog. As is usually the case you see better with fog lights only in heavy fog conditions.
3. The light color of the 2100s is identical to the HID.
4. I found the placement options very restrictive as there is very little metal around the grill to properly attach the lights.
5. The end result (anticipated) is that I will have a custom grill made and install (working on the design type and material option). This is partly because I also installed an Escort SRX anti RADAR and Laser device. My ultimate goal is to keep everything except the lights “private” without affecting airflow and to improve the overall look. I will patiently look for a cost effective solution, but for now I have eliminated all the loosed ends from the grill, and it does not look that bad, IMO.
Old Nov 24, 2002 | 10:37 AM
ares's Avatar
ares
Veteran
ooo I like that actually, breaks up the big "space" with some white. might try that next weekend.
Old Nov 24, 2002 | 03:23 PM
Zmeflyby's Avatar
Zmeflyby
i personally think that small round fog lights will look better.
Old Nov 24, 2002 | 05:06 PM
ares's Avatar
ares
Veteran
this is what Im gonna be using. grabbed them off ebay actually 2 years ago for 150$. brand new in box
Old Nov 24, 2002 | 05:40 PM
acid burn's Avatar
acid burn
Thumbs down NAY
But if you absolutely must, little round ones would look better.
And could you turn them off until they are actually needed? Thanks.
Old Nov 24, 2002 | 09:20 PM
SHO-TIME's Avatar
SHO-TIME
zeeing
Do you have better pix of your car from the front showing the fog lights, than the one posted in the SD Run thread?? I'm interested in seeing how they look from the front.
Old Nov 24, 2002 | 09:25 PM
zblime's Avatar
zblime
Agree
I have started looking for appropriate fog lamps and install location.
I am leaning towards small round ones as well.
Rod
Old Nov 24, 2002 | 10:30 PM
roberto350z's Avatar
roberto350z
I used to have this g-friend. Not a ***** in ANY way...but whenever she had someone behind her with Xenon AND HID fog lights, she would flip them off without even thinking. Her reasoning was that that is an unconsiderate thing to do to anyone infront of you.
something to think about
Old Nov 25, 2002 | 10:01 AM
mydogscool's Avatar
mydogscool
Thumbs down
Old Nov 25, 2002 | 10:48 AM
ares's Avatar
ares
Veteran
well they were doing it wrong, sounds like your standard ricer fogs where they think fogs should point straight up at oncoming drivers, so they can show them off(you know fog lights have no actual purpose)
of course they would have their own switch as well... again we return to my car computer system that I want so I could use the touchscreen to turn lights on and off. but since that doesnt exist, I suppose I would use a rocker panel like I did in my last car with them.
we shall see, they would be low to the ground, and aimed down so they can cut through the fog which is a problem in GA. but then again, supposedly HID are better for fog then even foglights.
who knows what I will do. might be a bigger pain to install then they are worth.
Old Nov 27, 2002 | 01:22 PM
zblime's Avatar
zblime
I want to get a rocker switch installed in the space beside the heated seat switches in my Touring to control the lights.
nismo33
Jun 9, 2005 12:36 PM
Chebosto
Apr 11, 2005 01:04 PM
Chebosto
Feb 16, 2005 09:20 PM
cyberz350
May 2, 2004 02:22 PM
koba8
Jan 19, 2003 10:19 AM
