My LED lighting
Old Feb 17, 2006 | 11:54 AM
  #201
jhchan's Avatar
jhchan
Did anyone have luck finding a more reputable vendor for these LED replacements? I just finished reading the entire thread and sounds like the verdict is still out. What we really need is someone to make these with Luxeon Star LEDs. I just picked up a 1W flashlight and man are they bright! Also got a 9 LED cheapo model and its no where near as bright as the single Luxeon.
Old Feb 17, 2006 | 12:20 PM
  #202
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I've had good luck with the place I ordered my LEDs from.
Old Feb 17, 2006 | 12:48 PM
  #203
catback's Avatar
catback
Try POLARG and PIAA from Japan. J51 bulb (T10) works pretty good on 06 Zs.
Old Feb 21, 2006 | 04:27 PM
  #204
maxpowers's Avatar
maxpowers
Just installed my 06 tail lights. While I was at it I put my old red 9 LED bulbs from the tails into the turn signals and I agree they are not workable. Any body have some good LED 7440's that will work? I want LED turn signals!!!
Old Jan 24, 2007 | 08:16 PM
  #205
Z4lif3's Avatar
Z4lif3
just ordered the amber front turn signals and white front parking lights. $26.50 shipped!
Old Jan 26, 2007 | 05:16 AM
  #206
trescincuenta's Avatar
trescincuenta
That website now carries 3watt Luxeon bulbs in the size that fits are turn signals and reverse lights... Im thinking about trying them out....
Old Jan 26, 2007 | 07:22 AM
  #207
dragone2717's Avatar
dragone2717
This led keeps going out. I didn't put a resistor on it becuz I thought it would hold up. Do I need to get one? This is the second time in 4 months.
Old Jan 27, 2007 | 06:31 AM
  #208
trescincuenta
same here.. the wedge style bulbs with multi little leds on them burnout constantly... Im gonan try that new one they have on their website now that doesnt have multi little LED's
Old Feb 15, 2007 | 10:07 PM
  #209
VtotheZ's Avatar
VtotheZ
Crap I just ordered the multi ones for the parking front lights.. By any chance does this make the HID's look bad? Or does it kinda give it a better white look, and not so yellow?
Old Mar 13, 2007 | 08:22 AM
  #210
ZLadie2000's Avatar
ZLadie2000
Any luck with a good vendor, I also read the ENTIRE thread only to find out in the end that the vendor may not be reputable and heat issues causing burnouts. Is superbrightleds.com the place to go or not? I dont want to have to replace blubs every few months...
Old Mar 13, 2007 | 05:07 PM
  #211
Track's Avatar
Track
Originally Posted by Superhung
I have everything that's listed, except the license plate LED's.
Here's my take....
- Front amber LED turn signals = Not brighter, but give a more crisp/clean look
over stock.
- Rear clear LED turn signals = Definitely brighter than stock, looks
awesome at night. I was very happy with
these.
- Front clear LED parking light = Looks awesome but doesn't match the
stock HID. Parking light is more blue than
white, while the HID is more white. 6000K
headlights would match perfectly.
- Rear red LED brake/tail lights = I didn't see a difference with these bulbs.
Maybe a tad bit brighter, but save your
dough.
I will post pics later tonight if I don't go out w/ my g/f =)
What about the back-up lights?
I am looking for a way to make mine much, MUCH brighter. Are LED's a way to accomplish this, or will I just end up with more of a "color change," such as a whiter light?
Old Mar 22, 2007 | 07:25 PM
  #212
Nerek's Avatar
Nerek
I heard LEDs from SuperbrightLEDs.com tend to last only a few months after burning out...on my old car i had a few in the headlights and the taillights and after a few months they died out...
Old Apr 2, 2007 | 06:46 AM
  #213
sexy350z's Avatar
sexy350z
just curious..says theres a warning for using the wled-6led in a headslight housing..have u had any trouble? or is that just for non hid headlamps?
Old Apr 26, 2007 | 03:20 PM
  #214
350ZIvy's Avatar
350ZIvy
nice find...................
Old May 2, 2007 | 09:24 AM
  #215
bbs350z's Avatar
bbs350z
^+1
Old Jun 15, 2007 | 05:19 PM
  #216
gabez33's Avatar
gabez33
I love LEDS
Old Jun 17, 2007 | 01:57 AM
  #217
Accordaleer's Avatar
Accordaleer
Ok sooooooo has anyone found a solution to this problem? I personally just need some nice white reverse lights,dome lights, license plate, and parking lights, my turn signals will all be chrome bulbs. So any ideas on If i can get bulbs instead of led i guess that are nice an white? i almost ordered all those leds, thank god i read all the pages.
Old Jun 18, 2007 | 01:33 PM
  #218
brabb1's Avatar
brabb1
Default undersill leds
does anyone know where I can get white undersill leds? I bought them a few years ago (like 8 groups on each door) and because the Z is so low they get scaped off on speed bumps and stuff. thanks!
Old Jun 19, 2007 | 09:46 PM
  #219
Nerek's Avatar
Nerek
I'm actually looking for 2 license plate bulbs or led's as well.just last night after about 2 months or so, my right plate light started to flicker then died out..also the front right parking light led is starting to burn out..
Anyone have suggestions?
Old Jun 20, 2007 | 06:45 PM
  #220
Xenor's Avatar
Xenor
Yes. The issue is that a lot of these bulbs are setup with resistance to run at 12 volts, probably 20 to 30 milliamps, and 3.5v forward voltage. When you run you're car, it's at ~13.6 volts. That said, more voltage makes more amperage and voltage throught the resistor and into the LED. The proof, go to superbrightleds.com and look at the specs of their bulbs. I found that the only bulb that doesn't blow/blink is the single wled 192 bulb because it's not so overpowered at 13.6 volts.
What I did:
I run single led bulbs in the parking lights, custom made 7 LED JDM clear reflectors I made with appropriate resistance at 13.6 volts. Similarly, for the license plate lights, I installed 4 white 5mm leds in each housing and wired them securely to the stock harness.
