Led Lights Purchased~
Old Jul 9, 2005 | 09:33 PM
gqnamja83's Avatar
gqnamja83
Default Led Lights Purchased~
are the front blinker lights in LED illegal in white? I live in cali..answeres will be appreciated cus I need the answer soon~
Old Jul 9, 2005 | 09:35 PM
ares's Avatar
ares
Veteran
yes; turn signal lights must be amber by law. further more; Im not aware of any DOT approved LED lighting options. piaa might be now; but I dont think so.
Old Jul 9, 2005 | 09:39 PM
DBZCat's Avatar
DBZCat
**** The P@lice
Old Jul 9, 2005 | 09:52 PM
gqnamja83's Avatar
gqnamja83
^^^ lol~
Old Jul 9, 2005 | 10:47 PM
jmcmorante's Avatar
jmcmorante
Im looking for this where did you get them? Pics?
Old Jul 10, 2005 | 03:08 AM
gqnamja83's Avatar
gqnamja83
ill post pic like next week when i get em installed. you can go to zcarparts.com for it though. good luck~
Old Jul 10, 2005 | 06:36 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
DOT federal law - amber only. I did mine an month ago and haven't had any issues with them. Some people were saying that the head from the HID and high beams would cause the temperature to rise to the point were LEDs would fail. I can see their point but it hasn't happened to me yet.
Make sure you buy the resistors to match or your lights will blink triple fast which will really get tiring after awhile.
I figure when I get done with the window tinting, no front plate, test pipes, twin-turbos and non-DOT approved lights that if the cops pull me over I'll just have to buy a new compliant car to fix the tickets that will come.
I've never been one to enjoy the law.
Old Jul 10, 2005 | 10:21 AM
gqnamja83's Avatar
gqnamja83
paul what did you do to your headlight in the pic? i see the yellow bulb is white and the bottom light is blue? where did you get those?
Old Jul 10, 2005 | 10:27 AM
B-Unit's Avatar
B-Unit
Originally Posted by DBZCat
**** The P@lice
+1, if a cop pulls u over for LEDs i would just laught at him.
PS: Cat wtf is up with your avatar area?!?!?!
Old Jul 10, 2005 | 12:28 PM
HockeyZ39's Avatar
HockeyZ39
non-DOT approved lights? I am currently contemplating doing a light retrofit to full projector using S2000 bulbs..... Are you talking of converting to full projection with ECE specs??? Thanks in advance..... And hey can you link me to your old thread that gave the step by step how to get the wheel well off to access the lights! Thanks a ton!
Old Jul 10, 2005 | 12:47 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
https://my350z.com/forum/showthread....14#post1560014
ECE specs???
I have swapped out the 50w lights for 100w ones which is illegal. I've done this on every car hi-beams I've owned since 1980 ... haven't been stopped yet. Nobody in Calfornia actually uses high-beams ... they either just drive around with their low-beams or high-beams all the time and never switch them on or off.
Old Jul 10, 2005 | 12:50 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
I got the Halogen high-beam lights at www.autohalogen.com
I get my LED's from either www.SuperBrightLEDs.com or www.autolumination.com
When standing next to the car it's much harder to see the blue tint of the Halogen lamp's cover than when you're down level with them like the picture.
Old Jul 10, 2005 | 10:58 PM
ONEDVSMOFO's Avatar
ONEDVSMOFO
In CA, the front turn signals can be amber or white. The rears must be red or amber.
24953. (a) Any turn signal system used to give a signal of intention to turn right or left shall project a flashing white or amber light visible to the front and a flashing red or amber light visible to the rear.
Old Jul 10, 2005 | 11:02 PM
gqnamja83's Avatar
gqnamja83
thanks that helped alot :~
Old Jul 11, 2005 | 09:45 AM
HockeyZ39's Avatar
HockeyZ39
ECE specs???
Oh i thought u ment the normal lights not the hi-beams.... ECE is the european spec lights. They have close to zero light above the cut off line, so the flicker is VERY aggressive!
Hey by any chance would you know how to get to the rear blinker lights? the person who had my car be4 me put clear/bluish bulbs in and i have been pulled over for it already, i have some of those silver coated amber bulbs but i have no idea how to get into the back... Also you can get to the blinkers in the front from that same light pod where you changed out your hi-beams right? Thanks in advance!
Uriyo_
Sep 8, 2021 08:46 AM
Mattg350z
Oct 2, 2015 06:51 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
