Light problems.....
Old Oct 14, 2005 | 08:05 AM
squall35's Avatar
squall35
Default Light problems.....
sup guys ,
i have a base model and i've installed some OEM HID that i bought from Jun ( who was excellent - buy it from this guy )...but since the installation , i am not able to leave the parking lights on only...the HID lights are always on when the car is running.......what went wrong .???
Old Oct 14, 2005 | 08:39 AM
maxpowers's Avatar
maxpowers
Did you wire them into your high beams? As your probably aware, the Canadian cars (with DRL) send reduced positive voltage to the high beams when the low beams are off. What happends when you switch to high beams?
Originally Posted by squall35
sup guys ,
Old Oct 14, 2005 | 09:19 AM
squall35's Avatar
squall35
i just followed the instructions ...the high beams are working fine ......maybe is not after the installation of the HID lights cause i didnt realise it before that ....some wire problems .??? its starnge that this happens only when the car is on, i cant turn them off..
Old Oct 14, 2005 | 11:35 AM
3PhidyZ's Avatar
3PhidyZ
I had installed aftermarket HID's on my old car and had the same problem, but what it was was the HID ballasts were not mounted securely enough and they were touching metal and completing the circuit, and keeping them on constantly, do not know if this helps but good luck.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
