Vented hoods, CF and other junk
Old Nov 4, 2005 | 04:33 PM
Oleg's Avatar
Oleg
Default Vented hoods, CF and other junk
My hopes of having my car parked in the garage have gone down like the Hindenburg over Lakehurst (can't clear driveway, even on stock height, at angle or otherwise). Certain thing on my shopping list must be revised. We do snowstorms in winter and rainstorms in fall (oh, Californians, don't get too happy, we don't get earthquakes, just kidding) Anyway, to keep the engine bay temps down (getting TN ST) I was planning to get a vented hood (like veilside stage 3 or the one from Power Enterprise). So, how does carbon fiber stand up to elements? What about fiberglass? If I make a cover to stretch over the hood to keep the elemental crap out, what will the trapped moisture do to the paint? Maybe I should just cut vents into the stock hood. I know it's aluminium, so rust is not an issue, but aluminium is such a bastard to do any kind of fabrication on... Either way it sucks... Which way sucks less?
Old Nov 4, 2005 | 05:14 PM
Chebosto's Avatar
Chebosto
all the vented hoods that i've seen weigh more than stock... disappointing.. and some even limit the use of the stock strut bar ...
depending on the mfg, and the resin they use. CF will hold up relatively well in direct sunlight and rain... not quite sure about snow since with snow you have salt and with salt, everything gets jacked up...
you'll probably be happier with cutting your stock hood and venting it that way, or buying a stock OEM style hood and adding your own holes.. which is what i'd mostlikely do...
if u vent ur aluminum hood, the body shop will most likely need to repaint the surface to prevent corosion.. OR if you cut louvers into the hood they will probably use fiberglass to make the side pieces.. either way. you'll need a repaint and with that you should be ok to the elements.
Old Nov 4, 2005 | 06:01 PM
nickintempe's Avatar
nickintempe
I'd mod the driveway...
Old Nov 4, 2005 | 06:05 PM
Oleg's Avatar
Oleg
Modding the driveway is it out of the question. There 13 other families in the condominium. The board will never allow it.
Old Nov 4, 2005 | 06:26 PM
The Nissan cover is a lifesaver. About $200.
Old Nov 4, 2005 | 06:28 PM
Oleg's Avatar
Oleg
You know, I heard that these covers do more harm then good by trapping moisture inside. I may be wrong though...
BTW what do you guys think of this hood?
http://www.350zonline.com/store/cust...cat=128&page=1
Old Nov 4, 2005 | 06:29 PM
Oleg's Avatar
Oleg
nice, simple and clean, no?
Old Nov 5, 2005 | 02:40 AM
disturbed2483's Avatar
disturbed2483
very clean, but a couple peeps had problems with stock strut bat clearance
Old Nov 5, 2005 | 05:33 AM
Queens 350z's Avatar
Queens 350z
I'm from Queens so i know how much this weather sucks in NY. I say you save your money that you would spend on the hood and just buy a winter beater. Driving the Z in the snow SUCKS.
Old Nov 5, 2005 | 05:59 AM
Roger V's Avatar
Roger V
Why don't you have someone fix your driveway?
Old Nov 5, 2005 | 06:35 AM
Cambelsoop's Avatar
Cambelsoop
the problem with buying a winter ebater is insuring it.. and insuring the Z and a winter beater in NY, especialy brooklyn is almost impossible for a young guy. im 23 and they want an absurb amount for me to insure a 93 jeep wragler with a 2.5 motor...
crazy. making payments on my z, insuring my z, insuring my bike, and insuring a winter beater for 6 months means im gonna need a third job. i dont sleep as it is
i feel for u living in brooklyn and trying to insure a car is terrible...
Old Nov 5, 2005 | 10:05 AM
zachcrosen's Avatar
zachcrosen
I was 24 when I bought a beater last fall. I bought a '91 miata and used it as my primary driver and the Z became my recreational vehicle. My insurance went from $950 for the Z alone to $650 with the Z and the Miata. I also use Geico for my insurance and have not had any issues with them. I would recommend you look into this option.
Zach
Old Nov 5, 2005 | 01:30 PM
Oleg's Avatar
Oleg
Do any other bars work?
Old Nov 5, 2005 | 01:33 PM
Oleg's Avatar
Oleg
Thanks.
Actually, it's not as bad as it was before I hit 25. I am not afraid to keep the car outside, I have done it for 2 winters already. But this spring I am doing a lot of work to the car, now that I have bought the condo. I was concerned about the FMIC from the TN ST and vented hood not being too suitable for being outside under snow.
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
EnjukuRacing
Misc.
Sep 23, 2015 07:27 AM
PureR3d
Sep 10, 2015 06:23 PM
