Xenon Headlight Life
Old Dec 3, 2005 | 09:36 AM
kahuba's Avatar
kahuba
Default Xenon Headlight Life
Just curious if anyone has had to replace their bulbs. If so, how many "miles" did they last? How much to replace?
Thanks,
Andrew
Old Dec 3, 2005 | 11:14 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Google > HID D2R
Old Dec 3, 2005 | 11:18 AM
ZlleH's Avatar
ZlleH
Why D2R? Are our stock HID DTR? I thought DTS is what we wanted...
Isn't DTS = projectors and DTR = reflectors?
Originally Posted by Wired 24/7
Google > HID D2R
Old Dec 3, 2005 | 01:27 PM
Jun's Avatar
Jun
D2R = reflector = stock (because our headlights are a combination of projector/reflector, not true projectors, like the 06)
D2S = projector
Old Dec 3, 2005 | 02:03 PM
ZlleH's Avatar
ZlleH
So getting D2S won't do any good?
D2S = projector
Old Dec 3, 2005 | 03:09 PM
Jun's Avatar
Jun
for the 350z, i really don't think it matters. Since the light that the bulb emits needs to pass by a rectangular piece and then through the hybrid projector, the light projected should look almost the same (or barely noticeable if their are any differences).
If it was a true reflector housing, like the IS300, then a D2S bulb would be bad because the light is scattered all over the place.
Old Dec 4, 2005 | 10:53 AM
kahuba's Avatar
kahuba
^ Hey that's great!
Can anyone shed any light in regards to the subject of this thread?
Old Dec 4, 2005 | 01:00 PM
Jun's Avatar
Jun
So how are we suppose to know how many you drive with your headlights on?
If you mean how many hours do they last, i believe typical lifetime is about 3500+ hours. Let's say you drive an average of about 5 hours a day with your lights on, then that would be almost 2 years (estimate).
Price for the bulbs are around $100.
Old Dec 4, 2005 | 01:02 PM
kbiz's Avatar
kbiz
The pre-06 HIDs aren't true projectors... they designed them to utilize the reflectors on the sides of the lens as well as being focused through the lens. I think that's to increase the visibility for oncoming traffic. If you look at the assembly up close you'll notice that there are masking slats on the top and bottom of the bulb housing and probably the focal point is closer to the lens than inside the housing... this would cause a percentage of the light to be scattered by the masking slats and reflected by the two reflector arrays on either side. On the 06s the lens is much larger and I would guess that the lense has grooves on the back side which scatters a small percentage of light and allows the lens to be lit up enough to provide adequate illumination for oncoming traffic. If you reduced the amount of the top slat slightly, you'd probably get a bit more output but the side reflectors would dim. With the 06s they went with a motorized lower stat which cuts off the high beam portion thus they can go with a larger lens and elliminate the high beam section bellow. The pre-06 lens will be less efficient than the 06s... but how much is noticeable is questionable. Bi-Xenon assemblies have gotten much cheaper so it's no surprise that Nissan opted for it since headlights are a hot button for car enthusiasts... The type of bulb is a different subject all together... but if you use too week of a light source with a hybrid projector/reflector set-up, you'll get poor results. I don't know if the non HID headlights use the exact same projector assembly, but if so than that's probably the reason they chose that design; they could have one assembly for both options.
Old Dec 4, 2005 | 02:31 PM
Zivman's Avatar
Zivman
HID capsules should last at least 2000 hrs which roughly equates to about 7-10 yrs or better.
Old Dec 4, 2005 | 04:56 PM
Lemans350's Avatar
Lemans350
Lifetime isnt easily measured in hours, the number of on/off cycles will affect the life. Try not to turn them on and then off quickly, or cycle the engine with the lights on. Xenons need to "warm up" ..you'll notice when you first turn them on the color gradually changes.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
JGee450
Sep 30, 2015 04:32 AM
