Replacing every bulb tonight and have NO idea how. HELP!
Here's a list of the bulbs i have to install tonight. Problem is, i've never done any of them before and have NO idea how to do it. Nor do i know how to remove bumper, headlights. etc. Help!
- HID: 14000k McCulough
- Hi-beam: Silverstar
- Daytime: Blue LED
- Front/Rear Blinkers: Clear LED
- Front Sidemarkers: Clear LED
- Headlight Diffuser Strips: Clear
- Daytime: Blue LED
search and you should find tons of write ups on this stuff. but to get you started, to get to the headlights I suggest jacking up the front of the car, put it on stands. remove both front wheels, then remove the fender lining by popping off the plastic rivet things with a flat head screw driver. you may also need to unscrew a couple of philips head screws and/or 10mm bolts. I don't really recall. but after taking off the lining you will see the back of the headlight which will have a grey circle cover which you turn counter clockwise about 1/4 turn and it should pop off. then you will have access to the bulbs. good luck.
Front light cluster:
https://my350z.com/forum/exterior-and-interior/128023-front-led-turn-indicators-w-resistor-56k-warning.html
High beams:
https://my350z.com/forum/showthread....14#post1560014
Rear lights:
https://my350z.com/forum/exterior-and-interior/126426-how-to-change-out-rear-turn-indictor-lights.html
High beams:
Rear lights:
