Dumb ?
Old Feb 2, 2006 | 08:35 AM
Zhornet's Avatar
Zhornet
Default Dumb ?
ive been trying to take off the stock shift **** but have not had any luck. can anyone help me?
PS i feal stupid for asking the question
Old Feb 6, 2006 | 03:17 AM
Zhornet's Avatar
Zhornet
bump
Old Feb 6, 2006 | 03:23 AM
yorky500's Avatar
yorky500
Think you might be better doing a search on the forum. I am sure there must be 100's of threads on this.
Old Feb 6, 2006 | 06:55 AM
VenomZ's Avatar
VenomZ
so the trick is to get a pair of vice grips etc to clamp down at the base of your shift boot...then you can loosten your shifter
Old Feb 6, 2006 | 11:48 AM
z350boy's Avatar
z350boy
I did this recently and it was a breeze. Her's how:
(1) To remove the shift boot you have to grasp the console where the shifter is located from the back. Gently but firmly lift up until it snaps out.
(2)Once that's done you pull the front portion of the console downards and it will come loose. BE CAREFUL WITH THE WHITE STRIP attached to the temperature control gauges. It's fragile and can break.
(3) Place a small piece of rubber tubing (ie bicycle inner tube) around the base of the shifter and clamp a vise grip plier to it. DON'T OVERTIGHTEN!!! Place another piece of rubber tubing around the shifter.
(4)Use another vise grip plier to turn the shifter counterclockwise while holding the plier gripping the base of the shifter steady. Take your time and the shifter should come loose. DO NOT UNDER ANY CIRCUMSTANCE ALLOW THE SHIFTER TO ROTATE WHILE YOU ARE REMOVING THE SHIFTER. THIS COULD RESULT IN DAMAGE TO YOUR TRANSMISSION.
(5) DONE!!!
Old Feb 7, 2006 | 01:21 PM
Zhornet's Avatar
Zhornet
is this for the whole shifter or just the ****
Old Feb 7, 2006 | 01:54 PM
Roggan's Avatar
Roggan
For the ****, what z350boy means is that you shouldnt let the "stick" itself rotate when you unscrew the ****, then you might risk damaging the trannie.
I had a bit of a struggle with this when i removed my stock ****, i was really scared that i might have snapped something in my gearbox as the **** was really tough to unscrew (wasent sure if the stick was rotating as well as the ****) basically the whole way until it finally came off!
Good luck
/Roger
Old Feb 7, 2006 | 02:51 PM
cracka350z's Avatar
cracka350z
i put a vise grip at the bottom...and just ripped the **** outa the ****....no longer recognizeable as a shift **** lol...
Dr.Paulyy
Jul 29, 2019 07:45 AM
Alexreyes
Sep 30, 2015 11:30 PM
rizzla
Sep 29, 2015 03:58 PM
shoalhaven
Oct 1, 2002 07:14 PM
