Where to mount hood pins?
Old Feb 10, 2006 | 04:32 AM
koolzero's Avatar
koolzero
Default Where to mount hood pins?
I'm getting ready to install some hood pins but I can't figure out a good place to attach the pins to. Do people drill through the bracing that is above the radiator?
Any suggest appreciated!
Old Feb 10, 2006 | 07:38 AM
Chebosto's Avatar
Chebosto
the radiator brace has two holes already, one directly above the intake hole, and one on the passengerside.
pins:
enginebay:
passenger side... the hole inbetween the two bolts,
driver side...
sorry for the crappy pictures. but i hope you get the idea.
Old Feb 10, 2006 | 08:55 AM
koolzero's Avatar
koolzero
I had thought about putting them there the only problem is that the pins I'm using:
need more of a flat space under the hood. There is an area that I found would be better but I would need to figure out a way to attach the pins behind the radiator...
Old Feb 10, 2006 | 09:07 AM
koolzero's Avatar
koolzero
I've got a question that's off topic when you have sponsors do they pay for your mods?
Old Feb 10, 2006 | 12:03 PM
Chebosto's Avatar
Chebosto
ahh you got the aerocatch.
there is two versions. one that is slimmer, and the other is normal size.. i *think* you got the normal sized one.
otherwise use their install directions,
http://www.aerocatch.com/AeroCatch-Brochure.pdf
check out page2
the slim version.
however,
the curvature isnt that bad @ that location. its actually smaller radius that you think...
try rotating the aerocatch horizontally.
Old Feb 10, 2006 | 01:52 PM
koolzero's Avatar
koolzero
I just ordered the other version I'm going to see how much smaller it is. Can you suggest a type of a saw that I could use to cut the hood with? The one they use in their directions looks like it would be the best because it *looks* like it lets you cut a straight slice pretty easily...
Thanks for your help!
check out page2
the slim version.
however,
Old Feb 10, 2006 | 02:02 PM
gringott's Avatar
gringott
That is not a slim version, that one is for mounting from underneath. In other words, the lip on one is on the outside, of the hood, the lip on the 125 flush is on the inside. In the directions, they suggest bonding it to the hood surface from underneath. I am thinking of mounting mine using the holes Cheston pictured, but of course, the underhood bracing or support structure is there, and in order to use the aerocatch, a chunk would have to be cut out in order to fasten the bolts to hold it in place. I am waiting for a full day to devote to this project, it turned out to be a big job IMO. I too am concerned about the radius there, but Cheston has a point about turning the areocatch on a angle to minimize the radius. I just hate to cut a hood in the wrong angle, there is no going back.
Old Feb 10, 2006 | 02:22 PM
koolzero's Avatar
koolzero
Here are some pictures of where I would like to make the holes:
These two spots line up very well to here:
and here:
The only problem is that I don't know of any thing to use to attach to those screws... This is something I drew up but nothing like this exists:
The latches I have are the same one as these:
Old Feb 10, 2006 | 02:40 PM
koolzero's Avatar
koolzero
I think the ones I have look like the 120 model?? but maybe I'm wrong..
Mine are completely flush like and don't have the concave... unless i misunderstood and the 125 is the slim version? Where can I buy the slim version?
Old Oct 23, 2006 | 12:54 PM
THE TECH's Avatar
THE TECH
You have any pics of how you mounted yours Koolzero?
Old Jul 27, 2007 | 05:58 AM
rx7/350z's Avatar
rx7/350z
can one of you guys post pics how you mounted these and which Monel you used. I'm really interested in getting these but if I mount them in the spot where the factory holes on the radiator support are will the areocatch clear the radiator support and will the angle of the pins work with the areocatch? The instructions say the pins have to be plus or minus five degrees of a right angle when entering the areocatch.
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
