Does the Veilside V1 lip fit w/ the stock under-spoiler plastic??
Old Mar 13, 2006 | 11:27 PM
j66's Avatar
j66
Default Does the Veilside V1 lip fit w/ the stock under-spoiler plastic??
i have the track pack 350z, and there is a front stock under plastic. i want to put the Veilside V1 lip on, and wonder if that plastic have to come off before the lip can go on? let me know is anyone have tried. thank you!
jackie
Old Mar 14, 2006 | 09:03 AM
barthelb's Avatar
barthelb
Master
You need not remove anything.
Old Mar 14, 2006 | 10:55 AM
A Keno Star's Avatar
A Keno Star
Nope dont have to remove anything, just bolt that sucker right on!
Old Mar 14, 2006 | 07:16 PM
MustGoFastR's Avatar
MustGoFastR
Fits just fine; have a V1 lip on my '03 track. Bottom of lip is at same level as bottom of that plastic under-spoiler and underneath edge sits a bit in front of it.
Old Mar 14, 2006 | 10:03 PM
j66's Avatar
j66
thanks for your replies , so i just need at 10mm screw to screw it in
Old Mar 15, 2006 | 08:10 AM
barthelb's Avatar
barthelb
Master
No, you use the stock existing 10 or 14mm can't remember that are on each side. There are two per side you use just those. All you need to do is rub the surface where the lip will contact the front bumper with Alcohol. Then apply double sided tape to certain areas and bolt it up.
Old Mar 16, 2006 | 12:40 AM
j66's Avatar
j66
i bolted on the lip, i have the CF one, and it seems that on the passenger side the lip is not staying up, which is making a little gap between bumper and lip. does anyone of you have that problem? is there a way i can adjust it?
Old Mar 16, 2006 | 08:17 AM
barthelb's Avatar
barthelb
Master
Did you use any double sided tape to secure the front and sides a lil better? If not thats what you need to do.
Old Mar 16, 2006 | 11:09 AM
j66's Avatar
j66
i didn't use any double sided tape, coz i throught the authenic stuff will fit perfectly, but i think that's what i'll have to do, coz right now is not aligned. i'll try to take it off and use double sided tape tonight, thank you very much barthelb for your reply =)
Old Mar 16, 2006 | 12:06 PM
MustGoFastR
My urethane v1 came new with double sided tape all along the upper edge. Didn't yours?
Old Mar 16, 2006 | 01:59 PM
FairLadeeeZ's Avatar
FairLadeeeZ
A lil off topic, but where is the cheapest place to buy the v1 lip, non cf?
Old Mar 16, 2006 | 02:41 PM
j66's Avatar
j66
i got the lip used, how thick and how wide was the double sided type, is it only on the upper middle part of the lip? let me know soon. i'll try to take it off and redo it again!
Old Mar 16, 2006 | 06:14 PM
MustGoFastR
Not very thick, grey stuff with red backing; looked like 3M BSM tape you can get at Autozone. All along the middle AND side areas (top edge); three separate pieces.
Old Mar 17, 2006 | 09:31 AM
VO...'s Avatar
VO...
Administrator
http://www.i-m-racing.com/veve1frsp35.html
Old Mar 17, 2006 | 02:16 PM
j66's Avatar
j66
how is the finish on the CF lip, the one i got used, the clearcoat is like over dripping, and some bubbles, does anyone of yours have that problem?
Old Mar 17, 2006 | 08:37 PM
FairLadeeeZ
Anyone buy the v1 lip from intense motorsports? How is the quality on the paint if i get it painted through them?
Old Mar 19, 2006 | 07:52 AM
xfactor1315's Avatar
xfactor1315
Do all of intense motorsports lips come with the double sided tape? and has anyone had any probloms installing or fitting them?
thepostman
Oct 16, 2006 04:41 PM
Superhung
Southern California
16
May 14, 2005 02:34 PM
Starman
Nov 7, 2004 06:05 AM
Strife350z
Sep 10, 2004 03:43 PM
aalzuhair
Mar 4, 2004 03:38 PM
