350z Aerodynamic = 200MHP?
Old Apr 18, 2006 | 05:08 AM
BamBam's Avatar
BamBam
As I said, I am not sure, but if I can do 105mph+ in 3rd gear, are we saying that between 4th, 5th and 6th gears I will only be able to get an increase of 20MPH per gear set before each one maxes out..?
Old Apr 18, 2006 | 09:47 PM
taurran's Avatar
taurran
Having more whp won't change your shift points. You will fly through the gears faster, but will have to shift just as much. You will be at redline in 6th gear before you hit 200mph. If you up your redline, maybe, although I wouldn't be comfortable pushing it to 7100 or 8000 rpms in 6th gear unless your motor is built like a brick sh**house.
Old Apr 18, 2006 | 10:13 PM
Havok_RLS2's Avatar
Havok_RLS2
Originally Posted by taurran
The 03-05 coupe has a drag coefficient of .30. The Track model with underbody diffusers has a drag coefficient of .29.
This is equivalent to the modern Porsche 911.
Yeah, I think it's capable... with some taller gears.
^^ Best technical answer so far. ^^ Keepem coming guys. My buddy keeps tripping that it's not possible at all. I'm sure that taller gears and a wing for added down force in the rear and long enough strech of road should just about do it. I don't think that anything more than 400hp would be needed to seal the deal.
Old Apr 18, 2006 | 10:30 PM
BamBam's Avatar
BamBam
I understand what you are saying, makes sense to me. I guess it would just surprise me that each gear would only get me another 20MPH, but I guess I am redlining it in 3rd, so each time I shift it will only have a short distance to go before redlining again…
Very interesting and valid point. Thanks
Old Jun 14, 2012 | 11:06 AM
DunZcon's Avatar
DunZcon
Originally Posted by Stailey
I highly doubt that it is....
at 155 (the fastest ive gone... i think it cuts off at 156 if im correct) the back end wasnt very stable and the car felt like it was floating...
another 50mph and i think ull have a major problem, and loss of control would be pundent.
Car has been up to 160 and it was very grounded so has my buddies. with both have a large list of mods though. Everything from coilovers, lowered, sways, solid diff mounts, gt spec braces and stillen braces, and bbk's to stop at that speed haha
Old Jun 14, 2012 | 11:11 AM
03threefiftyz's Avatar
03threefiftyz
The stock 350z actually creates lift at speed....not downforce. This is especially so in the front. I'm going to guess that at that speed the front wheels are going to be way too light for my liking. Of course adding downforce means adding drag...which means you need more powa to get to 200.
Old Jun 14, 2012 | 11:16 AM
eltness350's Avatar
eltness350
The Untouchable
lmao! ^^ take off the rearview mirrors...tape up all the body panels, tons of downforce, my buddies father in law went 216 in a porsche 928 with 700whp with tons of body mods, ohh and he put about 200lbs of lead in the frame
(lowest point) to keep it stable....
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
nanotech
Oct 2, 2015 05:02 AM
