installing white bumper reflector lights
Old Jul 6, 2006 | 05:51 PM
rmatic09's Avatar
rmatic09
Default installing white bumper reflector lights
I recieved the white reflector lights under the headlights for my new 06 Z, and the instructions are in japanese.
It says i have to remove the whole bumper, is there any other way to do this?
If this is the case i have to do it professionally. Unless there is anyone in LI/queens who wants to help me out?
Old Jul 6, 2006 | 05:52 PM
VN_350z's Avatar
VN_350z
you can turn the wheel all the way to left or right for installation. No need to take out dat bumper
Old Jul 6, 2006 | 05:54 PM
3FITTTY's Avatar
3FITTTY
removing the bumper is easy, but you dont have to remove it to do the install, and you certainly do not need INSTRUCTIONS!!
Old Jul 6, 2006 | 06:17 PM
rmatic09's Avatar
rmatic09
So do i have to remove the tires? And then pull back the fender?
Old Jul 6, 2006 | 06:19 PM
VN_350z's Avatar
VN_350z
you dont have to...but if you want..that makes it a litte esier
Old Jul 6, 2006 | 06:22 PM
rmatic09's Avatar
rmatic09
Is there any thread on how to do this? So i turn the wheel all the way, and pull the fender back? Im assuming theres clips holding the fender in....
Old Jul 6, 2006 | 09:20 PM
sidewayz2's Avatar
sidewayz2
couple of bolts and bend innerfender out use small short screwdriver and a friend to pull back gently when needed and a little luck near the washer fluid holder and a little patience and then ..... done.
Old Jul 6, 2006 | 09:23 PM
mahont's Avatar
mahont
Removing the bumper is simple and makes swapping the sidemarkers very easy once it is off. Taking it off the first time might take a little bit of time because you will be afraid to break something but once you have done it once you will be able to put it back on and off in no time.
Old Jul 7, 2006 | 09:19 AM
ZLadie2000's Avatar
ZLadie2000
Yeah I just bought some clear side markers too. Was hoping to not have to remove the bumper. So I turnthe wheel all the way to the right or left, remove some bolts, pull back the fender cover and then what....??? (dont want to break anything...)
If I do remove the bumper do I need special tools??
Old Jul 7, 2006 | 10:53 AM
rmatic09's Avatar
rmatic09
Zladie, you can do it without the bumper removal, its just a bit more difficult. You need to turn the wheel all the way to right/left depending on which side you are.
The driver side is simple, remove one fender bolt, pull it back, and switch the lights.
You will need a small philips.
The other side however, has the windshield wiper fluid blocking the light, and it is very difficult to get ur hands behind it to remove, the screws, it is doable, you just need alot of patience and coordination.
If your willing to do it, then give it a shot, i had to remove 2 screws from the bottom of the bumper to help reach in, have a friend help you hold it.
Old Jul 12, 2006 | 09:12 AM
Blue_Z's Avatar
Blue_Z
see post 3, sort of explains it:
https://my350z.com/forum/media-share/190212-my-06-db-with-clear-reflectors.html
This was while the front of my car was on jackstands and both wheels were removed btw.
Old Jul 12, 2006 | 09:22 AM
hwood's Avatar
hwood
Take the bumper off. It is quick and easy to do, plus you won't cut your hands up trying to get between the wiper fluid and the bumper.
Old Jul 12, 2006 | 10:28 AM
mista350z's Avatar
mista350z
yea i took off the bumper half way. left the bolts under the bumper alone. just took of the plastic clips on the top and the side screws that hold up the fender. did it for the first time. no instructions. just looked at the screws that were holding the bumper and went from there. install took me like 30min.
i used a thumb size phillips screw driver and flat head to take the plastic clips off.
Old Jul 12, 2006 | 10:43 AM
SH82N-Z's Avatar
SH82N-Z
Video tape it or make picture thread of the DIY please for the other guys.
Old Jul 12, 2006 | 12:52 PM
mista350z's Avatar
mista350z
im sure there are several diy threads on here. try searching.
Old Jul 13, 2006 | 09:36 AM
maxpowers's Avatar
maxpowers
I posted some tips on this before. Just search.
Old Jul 13, 2006 | 09:43 AM
usmanasif's Avatar
usmanasif
Some help here: https://my350z.com/forum/body-interior-exterior-and-lighting-diy/203246-how-to-front-bumper-removal-l-e-d-clear-corners-install-w-pix-ares-s-06-ccs.html
kyin
Oct 15, 2015 05:54 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
