350Z LED clear reflectors
Old Aug 11, 2006 | 05:39 PM
Mewantbfp's Avatar
Mewantbfp
Default 350Z LED clear reflectors
Would these work on the Z they say they work for the Z and the G35. I just wanted to know if that was correct?
http://cgi.ebay.com/ws/eBayISAPI.dll...m=150017366460
Thanks
Old Aug 11, 2006 | 05:42 PM
RockerNJ's Avatar
RockerNJ
Pretty sure this is just for a set of bulbs, not the actual clear reflectors.
Vick781's Avatar
Vick781
bump
Old Aug 11, 2006 | 06:08 PM
Mewantbfp's Avatar
Mewantbfp
yeah i think your right. You think they would fit in the top of the headlight?
Old Aug 12, 2006 | 11:56 AM
MAXecutive's Avatar
MAXecutive
make sure you use voltage regulators on any LED application. If you don't you'll be replacing them every 3 months tops!
Old Aug 12, 2006 | 08:03 PM
ares's Avatar
ares
Veteran
where to begin...
for starters, the price is highway robbery.
check out www.autolumination.com or www.superbrightleds.com or about a million other places that sell the same chinese made bulbs that cost $.02 per bulb(lol think Im joking? if I was willing to place a 2000$ order, thats the price direct from hong kong)
moving on; the clear reflector in the G35 uses a 194 bulb; which of course does nothing for the un-lit 350z reflectors.
it does fit as the parking bulb and liscense plate bulb.
it is just quite interesting that half way down this page
http://autolumination.com/194.htm
you will see a 6led 194 bulb for 4.99 each. a full 50% of the ebay price.
and of course, buyer beware. the bulbs are 2cents for good reason. they are overdriven and under made. they tend to fail very quickly for LEDs that should last no less than 100 YEARS(or atleast the lifetime of the car one could hope) of typical use if manufacturered correctly.
hopefully Im not being overly negative, just stating the facts.
so as to not be a total downer, I will suggest you look into piaa bulbs. they are made to much higher standards.
these are new I believe(and rather expensive), no personal experience with them
http://www.amazon.com/gp/product/B00...nce&n=15684181
or what I had always seen used previously; and a bit more reasonable
http://www.autotoys.com/x/cust/produ...cat=266&page=1
Old Aug 13, 2006 | 10:39 AM
DIGItonium's Avatar
DIGItonium
I can't believe PIAA makes one of the LED 194 bulbs for like $200 a pair?! I saw it in a catalog somewhere.
Old Aug 13, 2006 | 05:04 PM
LightWerkz's Avatar
LightWerkz
Autolumination.com is a good place to get bulbs from.
Old Aug 13, 2006 | 07:16 PM
MAXecutive's Avatar
MAXecutive
any led made for 12v will not last. The reason why is because when your car is driving, your alternator outputs 13.8-15V. This causes the leds and resistors to burn out. The solution is to go to a local radio shack and use 12v voltage regulators. Don't matter what your system is outputing, you will always send 12v to your leds.
Case solved. I had ebay hong kong leds for over a year and not one burned out led. I drive a lot of long distance and after 3-4 hours of constant driving, your voltage can get as high as 15V.
davidm350
Oct 31, 2015 02:28 PM
Mw870
Oct 2, 2015 08:23 AM
3oh5z
Exterior
Sep 22, 2015 10:09 AM
_koubie_
Sep 20, 2015 06:34 PM
