Apparently There Is A Wrong Way To Install HIDs
Old Sep 24, 2006 | 10:31 AM
RiotWithin's Avatar
RiotWithin
Originally Posted by jinsei888
I don't see how 8K can possibly give you better lighting range than the oem 4300s...haha that's just not how lighting temp logic works
That's funny. My OEM bulbs were dull as hell (I could probably see 20 feet in front of me). 4300 is yellowish to me, 6000 is white. As for the people that like 8000k, me, it's done for an exotic look. When I used the high beams on my magnum, I couldn't tell they were on, that's how bright those 8000k bulbs were. I tend to believe what I see, not what I read. Sorry. Thanks to everyone else for the help.
Old Sep 24, 2006 | 03:58 PM
LightWerkz's Avatar
LightWerkz
Sorry but you werent able to see the high beams because the color of the bulbs was much bluer so it overpowered the oem white. If you couldnt see your highbeams up higher then your low beams then you have another problem.
4300 is brighter then 8000k, much much brighter.
Old Sep 25, 2006 | 12:05 PM
Jun's Avatar
Jun
the little ceramic tube that covers the return wire should be on the bottom side *under* the bulb, not on top. Make sure you got the right bulb too, D2S and D2R have different notches.
Obadabot
Jun 18, 2023 11:31 PM
