03 HID -> 06 HID swap problem. Please help.
Old Oct 25, 2006 | 10:32 PM
  #41
Volk350Z's Avatar
Volk350Z
Master
I just cut the center 2 pin off my oem bulbs
Old Oct 28, 2006 | 10:32 PM
  #42
Zincognito's Avatar
Zincognito
This is not a bad idea(bulbs) for 05 and below. Good **** man
G
Old Oct 30, 2006 | 07:50 PM
  #43
SixRB6's Avatar
SixRB6
Volk.. I took the bulbs out and the bulb has this grey plastic attached to it..So I am confused as to where I can find the "center pin" you cut...can you help me out???
Old Oct 31, 2006 | 08:52 AM
  #44
Built2shredZ's Avatar
Built2shredZ
+1, how do you remove the plastic part without breaking it?
Old Oct 31, 2006 | 01:14 PM
  #45
SixRB6's Avatar
SixRB6
Help us!!! LOL
Old Jan 25, 2007 | 05:58 PM
  #46
nd2spd's Avatar
nd2spd
Originally Posted by Ghost_shift
If you want your turn indicators to to work normally (not on constantly), and you dont want to hack up the car's wiring harness, all you have to do is take out the bulb from the plug, and cut the middle 2 wires so that they dont make contact. There is one on one side, and one on the other. Remember, its the middle pins/wires.
Pics....
Could you please re-post the picture of the bulb wires that must be cut. Thanks
Old Feb 20, 2007 | 03:10 PM
  #47
Track's Avatar
Track
Subscribed and awaiting (and hoping for) more detailed information and pics.
Old Feb 20, 2007 | 04:33 PM
  #48
davidf's Avatar
davidf
Sorry guys I have no pics. but it's not hard. With the unit plugged in and the harness visable, turn on the headlights and with a test light you probe the wires running into the back of the park lamp bulb.{there will be 2}. The one that lights up is gonna be the park lamp. But if your unsure then at the same time turn on the signal lamp for that side and the other wire should flash the test light like the blinker. Snip the other wire, that should do it. Note: this will not kill the side led's.
Old Feb 20, 2007 | 08:45 PM
  #49
Track's Avatar
Track
Thumbs up
Outstanding!
Thank you for such a pithy and concise explaination. Although I've read many accounts of this solution, yours is the first that I could understand (without having the unit in my hand as I read it).
Old Feb 20, 2007 | 08:47 PM
  #50
Track's Avatar
Track
The light housing unit, that is. Not my own.
Old May 11, 2007 | 04:36 PM
  #51
synth19's Avatar
synth19
This is a great thread, tell me more abou the equalizer, how does this work actually? What do you mean by "wire in an equalizer?" How do you install this and which ones is it? THANKS
Originally Posted by ilbkuup
plus you'll need to wire in an equalizer on each headlamp which are $8.99 each.
Old May 11, 2007 | 05:53 PM
  #52
BallZdeepNYC's Avatar
BallZdeepNYC
Can you change that strip of 4 leds from amber to white. are they replaceable bulbs or hardwired?
Old May 11, 2007 | 06:19 PM
  #53
ilbkuup's Avatar
ilbkuup
Newbie
Good luck with changing out the amber led's. I was going to but you would have to take apart the entire housing to get to them. Not up for breaking the housing seal if I didn't have too.
Old May 12, 2007 | 09:06 AM
  #54
synth19's Avatar
synth19
can someone answer this question:
Old May 12, 2007 | 10:20 AM
  #55
Track's Avatar
Track
Not me, but I can try to help explain for now (until one of our wiring gurus sees this thread).
When you replace your front turn signals with LED's, they don't have any resistence (like the OEM bulbs), so this causes them to blink too fast or even blow out, because they use much less current than the OEM bulbs.
The "equalizer" prevents both of these.
Hope that helps. Someone will no doubt now be challenged to correct me or add anything I left out, so then you'll have your answer.
Old May 12, 2007 | 06:19 PM
  #56
synth19's Avatar
synth19
^ That, I know. What I meant I really am not sure about the installation oof the equalizer and what "wiring" is needed. Thanks
Old Dec 22, 2007 | 05:11 PM
  #57
mw9's Avatar
mw9
subscribing
Old Mar 1, 2008 | 12:16 PM
  #58
dgkn86's Avatar
dgkn86
is this bulb going to work on 05 headlight?
Old Mar 12, 2008 | 02:40 PM
  #59
c-los350z's Avatar
c-los350z
does anyone have picture to picture instructions.
liqalu04
Jan 2, 2022 12:58 PM
Pleask
Dec 21, 2021 03:17 PM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Uriyo_
Sep 8, 2021 08:46 AM
3vilbunny
Jul 18, 2017 05:10 PM
