Need help installing illuminated foot lights.
Old Mar 15, 2003 | 10:34 AM
MacGuru's Avatar
MacGuru
Default Need help installing illuminated foot lights.
I'm installing the Illuminated foot lights and need some help with the Japanese instructions. From what I can see, the wiring is pretty simple, it's just making I've picked the correct wires. Color codes don't seem to match, but I could just be looking at the wrong place.
I know SkiDazzle installed these, but I can't seem to find his thread on the install. That is if there is one. After I've completed the install I'll post a how-to and step-by-step for those thinkning about installing the foot lights.
Does anyone have the wiring diagram for the fuse box? This should help me tremendously.
Any help is greatly appreciated.
Cheers,
-m
Old Mar 15, 2003 | 02:12 PM
MacGuru's Avatar
MacGuru
ok, here's what I figured out so far. Looks like the diagram supplied (japanese) is reversed (flipped).
I managed to get the foot lights to work by hooking the main lead (red/illum) to the (green/wht) wire in the fuse box and I connected the (2) blue wires, which I would presume are the turn-on leads for each door down on the BCM. I don't believe I'm taping into the right wires for the BCM. Everything I've tried leaves the foot lights ON, even after the dome light goes off.
I've attached some pics, maybe this will help.
Thanks. -m
Old Mar 15, 2003 | 02:41 PM
MacGuru's Avatar
MacGuru
Here's the fuse box.
Attached Thumbnails Need help installing illuminated foot lights.-350z_fusebox.jpg
Old Mar 15, 2003 | 02:42 PM
MacGuru's Avatar
MacGuru
Here are the instruction diagrams 1 of 2.
Attached Thumbnails Need help installing illuminated foot lights.-350z_illumlight_diagram1.jpg
MacGuru's Avatar
MacGuru
diagram 2
Attached Thumbnails Need help installing illuminated foot lights.-350z_illumlight_diagram2.jpg
Old Mar 15, 2003 | 06:01 PM
MacGuru's Avatar
MacGuru
Can anyone read Japanese?
If so, could you help out a fellow Z owner by translating the instructions?
I can email you a PDF version of the instructions.
Thanks, -m
Old Mar 16, 2003 | 05:49 PM
mysteriumZ's Avatar
mysteriumZ
Charter Member #101
dude check your pm
Old Mar 16, 2003 | 07:40 PM
MacGuru's Avatar
MacGuru
Thanks. I responded. -m
Old Sep 13, 2009 | 03:42 PM
l8r's Avatar
l8r
Bump for help if anyone can PM me.
My BCM looks like: http://i105.photobucket.com/albums/m...-BCM_Small.jpg
Original instructions, much larger:
http://www.courtesyparts.com/instruc...0-Z33KT_1.html
R/B = Red with Black stripe
L/W = Blue with White stripe
L = Blue
P = Pink
My BCM doesn't match either the instructions either.
Thanks!
My progress, yet still no luck: https://my350z.com/forum/pacific/455...re-manual.html
Old Sep 14, 2009 | 12:26 PM
l8r's Avatar
l8r
Bump.
Didn't know 2003-2004 had a different BCM than the 2005. That is why I can't match the wiring up. Anyone else installed this?
Old Sep 14, 2009 | 02:55 PM
Kwame's Avatar
Kwame
I have this in my car but I have an '03 so I cant really help you.
Old Sep 14, 2009 | 03:59 PM
l8r's Avatar
l8r
Bump!
