Broken Cup holder on passenger side
Old Nov 1, 2006 | 06:22 AM
cmtuggl's Avatar
cmtuggl
Default Broken Cup holder on passenger side
For no apparent reason, the cup holder on the passgener side - the one that comes out from the console - gets stuck every time I push it back in. I can get it out by prying, but of course I don't want to do this! I can't see what it's catching on... Does anyone else have this problem?
I welcome any suggestions for what to look for or possible fixes!
Old Nov 1, 2006 | 06:29 AM
StreetOC192's Avatar
StreetOC192
I used to use mine every day, but one day a couple weeks ago, it got stuck and won't come out. I haven't had the time to look into this. I hope someone has a quick fix. Just wanted to let you know, you are not alone!
Old Nov 1, 2006 | 11:07 AM
bam025's Avatar
bam025
in the same boat.....
Old Nov 1, 2006 | 11:16 AM
-EL's Avatar
-EL
Mine got a tiny bit of soda on it and suddenly decided to be very finicky, sticking closed most of the time. I took it out of the dash and cleaned it out very thoroughly, put it back in and it works perfectly.
-E
Old Nov 1, 2006 | 11:17 AM
Mazinger Z's Avatar
Mazinger Z
Me too, I'm thinking it's because the stupid thing is a pretty snug fit and when you put drinks in there, the condensation causes the locking mechanism to get stuck. Damn engineers...
Old Nov 1, 2006 | 01:18 PM
OrangeJZ's Avatar
OrangeJZ
Mine has gotten jammed twice already. I take it to the dealer and they're able to fix it but when I asked them what was wrong with it, all they can reply is that it was stuck. Well no ****! Just take it to the dealer and your problems should be resolved.... until the next time it happens.
Old Nov 1, 2006 | 01:25 PM
Quijano187's Avatar
Quijano187
same here, i just punch mines to get it out and punch to get it to close
Old Nov 1, 2006 | 01:30 PM
Eazzy's Avatar
Eazzy
If you pull it out and slip a very thin screwdriver straight in on the top center, u will reliese it and it will pull out as a unit. Inspect it. There is a spring loaded latch that breaks and will cause u to be cup holderless
Old Nov 2, 2006 | 10:37 AM
cmtuggl's Avatar
cmtuggl
Thanks EL and Eazy - I'll try what you suggest tonight!
Old Nov 3, 2006 | 07:40 AM
cmtuggl's Avatar
cmtuggl
cleaning and lubing seemed to do the trick. Thanks guys
Rev_Night
Nov 7, 2020 06:00 PM
Dymsi
Sep 29, 2015 11:32 AM
samansharif
Sep 25, 2015 12:31 PM
