blue LED conversion, '06
Old Feb 3, 2009 | 01:03 PM
LEDmod's Avatar
LEDmod
I had a set custom made
Old Feb 5, 2009 | 03:49 PM
BLUENIS350's Avatar
BLUENIS350
my car looks nice. Thanks
Old Feb 5, 2009 | 09:21 PM
KYEXTAZ's Avatar
KYEXTAZ
sorry to get off topic here but I saw you LED masters. Any chance you would check out my thread about resistors to answer a question?
https://my350z.com/forum/exterior-an...ml#post6915371
Old Feb 6, 2009 | 03:32 AM
jdm ruben's Avatar
jdm ruben
i have an 08 and im patiently waiting for someone to pull the whole conversion to blue so i can buy it already
Old Feb 6, 2009 | 11:48 AM
LEDmod's Avatar
LEDmod
http://store.ledmod.com/index.php?ma...products_id=62
Old Feb 6, 2009 | 02:18 PM
jdm ruben's Avatar
jdm ruben
is it for an 06 and up i couldnt see it anywhere on there and wat about the radio controls doesnt look like a bad buy tho....
Old Feb 6, 2009 | 02:27 PM
LEDmod's Avatar
LEDmod
All model is pretty much the same..
For 06-08 climate control is little different (It's harder to do)
Don't have the picture for the radio, but it can be done, no problem..
Old Feb 10, 2009 | 03:33 AM
Jons 350z's Avatar
Jons 350z
any ideas on where to start with this conversion on a 03 350z. i have 18 days of time to fill while im home from iraq. thanks
Old Feb 10, 2009 | 04:03 PM
LEDmod's Avatar
LEDmod
For do it yourself??
Old Feb 10, 2009 | 05:24 PM
ZRuggernDC's Avatar
ZRuggernDC
Reference the member named Acree
He has a DIY about the conversion... Hope that helps. Good luck. Hope you are good with small leds and all that....
Old Feb 17, 2009 | 04:44 PM
LEDmod's Avatar
LEDmod
DIY was kind of taken down I think...
Old May 15, 2009 | 09:39 AM
revho's Avatar
revho
Can anyone tell me where I can order the LEDs for the climate controls?
Old May 15, 2009 | 09:48 AM
LEDmod's Avatar
LEDmod
E-mail me and I can set up a kit for you
Sean@LEDmod.com
Old May 15, 2009 | 11:34 AM
lbz's Avatar
lbz
part numbers for blue LEDs for 03 - 05 are
LB T67C-P2R1-35-Z you will need 8 of these
QTLP610CEBTR you will need 12 of these
both available at www.mouser.com
Should be easy enough to find other colors if desired
Old May 16, 2009 | 11:11 AM
adamtaylorpcb's Avatar
adamtaylorpcb
so what about for a 06 6mt enth
Old May 16, 2009 | 02:34 PM
lbz's Avatar
lbz
For 06 you would need only 4 of the LB T67C-PRR1-35-Z
and 9 (3 for each ****) of the smaller 0603 package which you can find get using the link below
Per LEDMODs comment earlier, the smaller 0603's are harder to work with but with the right equipment and skill level, not impossible.
http://www.mouser.com/Search/Product...1lwthlLHo83OSA
I've started a full DIY that covers the door handles, the AC controls, the center console gauges, the steering wheel gauges (including blinker indicators) as well as the hazard signal switch, dash alarm LED and rear hatch light.
The door handles and AC controls sections are already posted. I expect to post the center console section later today and the other sections next weekend as I still have some parts on order.
BUT, my post is only for 03 - 05. The other difference on the AC controls, besides the different LED's, is that the control ***** are soldered to the board, not screwed in.
Here's the link to my post. When I get all the sections done, I'll have the mods clean it up and move it to the DIY section. Meanwhile, the first two sections are available in PDF if you PM me.
https://my350z.com/forum/exterior-an...e-out-kit.html
Dsowe
Feb 17, 2021 10:38 AM
Jambo016
Sep 16, 2016 01:08 PM
kyin
Oct 15, 2015 05:54 AM
350z82
Oct 1, 2015 06:25 PM
