350z rear woofer panel removal
Old Jan 13, 2007 | 04:22 AM
jonny407's Avatar
jonny407
Default 350z rear woofer panel removal
I have been looking all over for instructions on how to remove the rear woofer panel behind the driver’s seat. I'm trying to install my basslink back there. Anybody know how to do this?
Old Jan 13, 2007 | 05:13 AM
Russ@Z1's Avatar
Russ@Z1
If you're talking about the metal, you'll have to remove all the plastics from that rear section first. The top side that goes across the car comes off first.
Old Jan 13, 2007 | 05:20 AM
MustGoFastR's Avatar
MustGoFastR
Bad news is you gota rip out half your interior to do it. Good news is you'll have to pull the console anyway to run wires.
Follow posts 1-7 of this tutorial:
https://my350z.com/forum/showthread....threadid=26837
THEN:
-open the glove box and remove the two screws around the latch.
-Pop that whole rear panel out and disconnect the 12v power socket.
-remove the 10-12 bolts holding that woofer panel in place, pull it out and discard it.
These write-ups may also be of use to you:
https://my350z.com/forum/showthread....threadid=26620
https://my350z.com/forum/showthread....threadid=26618
http://liljerk.morpheus.net/350Z/dash_removal/
All of these and more can be found in the Audio/Video/Electronics section of the forum.
Old Jan 13, 2007 | 06:23 AM
jonny407's Avatar
jonny407
THEN:
Thanks for the info. I know how to remove the center console and already ran my wires back. I'm having trouble removing the rear panel with the 12v power socket. this one;
You say after I remove the two screws in the glove box.
That the rest of the rear panel will just pop out? I was pulling hard but I was afraid to break something.
Old Jan 13, 2007 | 06:38 AM
MustGoFastR
Yes, it just pops off. I believe you have to pull those quarter panel pieces first, though, since they overlap this piece.
Old Mar 15, 2007 | 06:22 AM
three_fitty's Avatar
three_fitty
So do i have to remove the 12v power socket first before i start pulling the full panel off?
I'm having the same problems. I got half of the panel off, but to the point were the power socket is, it gets really hard. I dont want to break anything, help please?
Old Mar 15, 2007 | 06:46 AM
06blueZ's Avatar
06blueZ
I managed to remove the bose panel without taking off the whole back cover. You should be able to just get enough room to remove all of the bolts, and slide the panel out...
Oh, and on the basslink, dont use the line level inputs if you are using hte stock headunit.
Old Mar 15, 2007 | 07:54 AM
MustGoFastR
Nope, panel pops off, then unplug the socket from the back.
Old Mar 15, 2007 | 09:15 AM
three_fitty
Thanks!
Old Mar 15, 2007 | 09:33 AM
se-r / gti-r's Avatar
se-r / gti-r
subscribing so i can remember this post
Old Mar 11, 2011 | 01:15 PM
merick1207's Avatar
merick1207
Default subwoofer mounting panel removal
TO EVERYONE!!!! YOU DO NOT HAVE TO REMOVE ALL THE PLASTICS TO GET THE SUBWOOFER MOUNTING PANEL OUT... I JUST NOW DID IT IN UNDER 15MINS. IF YOU HAVE ANY QUESTIONS PLEASE CONTACT ME AT MERICKSAUTOWORLD AT AOL.COM PLEASE PUT 350Z IN THE SUBJECT OR I ILL SEND IT TO SPAM FOLDER
reno56
Interior
17
Nov 20, 2015 05:21 PM
Mattg350z
Oct 2, 2015 06:51 AM
FromGtoZ
Sep 20, 2015 03:41 PM
hardkicks
Sep 20, 2015 12:28 PM
PureR3d
Sep 10, 2015 06:23 PM
