Urethane headlight sealant??
Old Mar 14, 2007 | 09:04 PM
stepuckey's Avatar
stepuckey
Default Urethane headlight sealant??
Just wondering if anyone knows the best kind of sealant to use for sealing headlights. (keep out water) I read on some other post to use a self leveling urethane sealant as it works better than just regular permatex silicone stuff. I bought some 'PL polyurethane self leveling concrete crack sealant' at home depot. I'm assuming that will work fine, but if there is a better alternative please someone clue me in. TIA
Old Mar 14, 2007 | 09:38 PM
MustGoFastR's Avatar
MustGoFastR
If silicone can keep water in aquariums, I'm sure it'll keep water out of your headlights just fine...
Old Mar 14, 2007 | 09:57 PM
mrruins's Avatar
mrruins
make sure the sealant or silicone has some heat resistance to it.
Old Mar 14, 2007 | 10:13 PM
stepuckey's Avatar
stepuckey
THE only thing about the silicone is that it is hard to flow into the little cracks and crevices. That's why the self-leveling was recommended as it will get in there a lot better. I've used the silicone in the past, but had to do it like f-ing 3 times...and I spent a lot of time each time, thinking "surely this will fix it." it eventually did but - it took 3 times!! oh well, maybe there's no way to get around that?
Old Mar 21, 2007 | 09:57 PM
creationv2's Avatar
creationv2
what brand is the stuff you got from homedepot? i need some
Old Mar 22, 2007 | 09:24 AM
stepuckey's Avatar
stepuckey
I found it in the 'paint' department. You'll need a caulking gun though. It seems to have worked really well and was easy to work with. If you get some somwhere on your light that you don't want it to be, it wipes off cleanly and easily. Oh, but you don't need to put a ginormous bead though, as it's self-leveling and therefore can be a little runny. - One more thing, the kind I got only seemed to come in a grey color, and since I have an aftermarket hood, you can see some of the grey seams, so you might want to get some touch up paint and paint where the grey would be visible w/ the hood shut. (what I'm going to do) Good luck!
Old Mar 22, 2007 | 09:31 AM
redlude97's Avatar
redlude97
Use butyl rubber, you can get it from the nissan dealership, its what is used on stock headlights
Old Mar 22, 2007 | 10:14 AM
litlechina's Avatar
litlechina
just go to autozone and get the RTV silicone in a blue or white container. Get the one that is water proof. I have used them on two headlights and they have worked perfect
Old Mar 22, 2007 | 10:38 AM
stepuckey's Avatar
stepuckey
Dang!! Where were you about three days ago!! (I hope it's more expensive than $4.98 to make myself feel better.)
Old Mar 22, 2007 | 11:27 AM
creationv2's Avatar
creationv2
thanks for the info. and yah i realized pl was the brand O_o it was too late for me to figure that
Old Mar 22, 2007 | 11:37 AM
redlude97's Avatar
redlude97
Does the urethane remelt in the oven or is it permanent? Just in case you need to pull your headlights apart again
Old Mar 22, 2007 | 12:33 PM
creationv2's Avatar
creationv2
^^ how much is the butyl rubber stuff and is it also self leveling?
Old Mar 22, 2007 | 07:00 PM
stepuckey's Avatar
stepuckey
fwiw, the urethane I used, right down to the exact color, was exactly the same as the stock sealant that was used on my oem civic headlights. I pulled them apart myself using a heat gun and remember it vividly....so this stuff appeared to be exactly the same. ha, so to answer your question, there is no doubt in my mind the urethane will melt just like stock sealant. but in light of the new butyl rubber at nissan, unless it's $50 an ounce, I say stick w/ stock! (plus it's black)
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
PureR3d
Sep 10, 2015 06:23 PM
